| diyAudio Sponsor | ||
Help!Schematic tube output stage of CDP Audio Note AN-CD1(used DAC PCM 1710)....Help me!!!???
#2 |
As requested.
What do you plan to change in this old CD? |
#3 |
I'd suggest rewiring the heater and using an ECC88 instead..
#4 |
www.kta-hifi.net |
#5 |
Dear kevinkr and all Colleagues,
This is absolutely NOT the original schematic or any part of it. I have drawn this myself in ...CorelDraw Essentials, based on the original AN board on hand. I had never had the original schematic of AN CD1. |
#6 |
I also applied rewiring of heater supply for different tubes - 2 photos attached.
The schematic (not hand-made but CorelDraw-made...) with realised mods to power supply to DAC - attached. Please note, that the trafo is not "toroid" but "EI 40W" and it has also different heater windings than original, made by AN... Good luck! |
| J-fet - tube DAC analog stage | regal | Tubes / Valves | 0 | 11th November 2010 11:14 AM |
| Analog output stage for DAC (AK4584) | Ekkeri | Digital Line Level | 3 | 22nd March 2009 06:37 PM |
| Analog output stage for cd | sopapo | Solid State | 0 | 6th September 2006 08:17 AM |
| JVC XL-V1100 output stage schematic ? | Bernhard | Digital Source | 0 | 7th April 2005 07:58 PM |
| Analog Output Stage | Alien8 | Digital Source | 6 | 12th March 2004 09:02 AM |
| Page generated in 0.08288 seconds (76.43% PHP - 23.57% MySQL) with 11 queries |
