| diyAudio Sponsor | ||
I have a Magnavox 88-02 amp that has a bad power trans.
The schematic that I found (in another thread on this site) gives a value of 270 volts to the plates of the output tubes, but it doesn't specify the output voltage of the power trans. If anyone knows the proper secondary voltage and current ratings for the replacement trans, please let me know. I plan to order one from Edcor (unless you know of a source for one of these). Thank you. |
| Power ratings | GregH2 | Construction Tips | 11 | 25th September 2011 03:54 PM |
| Power supply resistors power ratings | Nihilist | Tubes / Valves | 13 | 31st July 2009 01:47 AM |
| Audiopax 88 Power Amp | apassgear | Tubes / Valves | 12 | 8th March 2003 08:03 PM |
| Power Ratings | BAM | Multi-Way | 1 | 13th October 2001 11:05 PM |
| Page generated in 0.06698 seconds (66.40% PHP - 33.60% MySQL) with 11 queries |
