diyAudio Sponsor
Old 17th May 2011, 12:29 PM   #1
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
Default Switchable SE.
Just a thought,
Has any one ever used switchable tubes in a SE or PP power amp.
Talking HIFI here.
For example, 3 X EL34 or EL84 SE and being able to switch off 1 or 2 of the EL34's etc to reduce power when not needed.
My question is the primary impedance of the O/P Tx and the change in load conditions / feed back. If this was cathode feedback and the EL34's were connected to the O/P Tx feedback winding as the common Gnd connection.
I guess the tubes would have to be fixed bias.
M. Gregg
What is the sound of one hand clapping?
Old 17th May 2011, 01:26 PM   #2
mastodon's Avatar
The biggest problem would be the DC current in the OPT, which will cancel out within the primary winding when in PP mode, but not so in SE mode, causing core saturation.
On a more abstract level, it doesn't sound like a particularly good idea to me. An amplifier, like any artifact of engineering, is a compromise that intends to achieve the best possible performance on a set of predetermined parameters. Starting out with two sets of potentially conflicting parameters sounds like a sure-fire way to get a crappy compromise for either set of parameters, or a good compromise for one set and a really bad one for the other.
If you need less power, then just install a volume pot.
Old 17th May 2011, 01:32 PM   #3
If you're doing parallel single ended then the primary of the OPT would have to change -- unless you use one transformer per power valve and then series the secondary windings (4R + 4R for an 8 ohm tap when in PSE mode). Then one whole section of the circuit could shut off for night-time listening, etc.
Old 17th May 2011, 01:40 PM   #4
M Gregg's Avatar
Thoughts are to shut the tubes down with Bias.
I know the other way is to triode connect to cut power.
I know that the the primary impedance is normally set for the tube, however how close has it got to be EL34 2.5K - 5k.
The other issue is cathode poisoning. (heater power off).
Its just a talking point at the moment.
Thoughts are 3XEL84 per side. Just for a fun test.
M. Gregg
Old 17th May 2011, 01:57 PM   #5
mastodon's Avatar
How would 3 tubes work in a PP setting?
Old 17th May 2011, 02:00 PM   #6
M Gregg's Avatar
I am thinking SE.
Old 17th May 2011, 02:04 PM   #7
mastodon's Avatar
Oh right, now I see I read your post wrong all the time. I thought you were trying to develop a concept that would switch between PP and SE.
What would the purpose be of switching off power tubes? Increase THD? Create impedance mismatch problems? I can see why this could be desirable in a guitar amp, but for hifi, I don't really see the application.
Old 17th May 2011, 02:20 PM   #8
M Gregg's Avatar
Its just an interest,
As you say guitar is an application.
However I was interested in powering off tubes and the problems linked to it.
M. Gregg
Old 17th May 2011, 03:32 PM   #9
DF96 is offline DF96  England
The easiest way to switch off an output valve is disconnect the heater. Unless you have silly HT voltages, no harm in it sitting there cold. Cathode poisoning occurs when the valve is conducting, but with temperature-limited emission i.e. cathode warm but not hot enough for normal space-charge-limited emission.
Old 17th May 2011, 03:45 PM   #10
M Gregg's Avatar
Thank's,
Do you see any issues with heater power up or down while another parallel tube is conducting. i.e. no output just idle current?
So in theory you could have a number of tubes sitting idle and select lets say an el34 or a 6550 and power up the heater to a tube.(As long as the bias was correct and OP Tx matched). So an "A" or "B" select. Or in a multi channel amp you could select just the channels required.
M. Gregg
Mcintosh autoformer taps.....Switchable? awangotango Solid State 0 17th December 2010 04:03 AM
Switchable 4 / 8 ohm speakers Brett Multi-Way 3 26th April 2009 11:32 PM
Idea for switchable bridge.... Tsanford Chip Amps 4 6th December 2006 10:04 PM
Switchable stages with Tubelab’s hybrid MOSFET/ 845 SE amp? rick57 Tubes / Valves 0 5th September 2006 07:56 AM
Switchable bias for the A75? jbateman Pass Labs 5 2nd March 2002 04:17 AM
Page generated in 0.10625 seconds (80.00% PHP - 20.00% MySQL) with 10 queries
