phase splitter issue
Old 9th October 2012, 03:32 PM   #981
CPaul is offline CPaul
Please post or give me a link to dm6l6.inc.
"It is error only, and not truth, that shrinks from inquiry." - Thomas Paine
Old 9th October 2012, 03:40 PM   #982
On Hiatus
SY's Avatar
Originally Posted by CPaul View Post
There is simply no experimental evidence to support the claim that Zpg = Zkg = 1/gm.
As long as the loads are equal, ALL of the experimental evidence is consistent with that. I haven't found an exception and, based on your one experiment, neither have you.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 9th October 2012, 04:24 PM   #983
Of course it's consistent. But only in the sense that it is not contradictory. Heater voltages of 6.3V are consistent with B+ voltages of 300V. That doesn't mean either one predicts or constrains the other. "Consistent" doesn't mean "implies".
There is not a single test for the Zpg or Zkg of a balanced Cdyne that you can point to that favors the value of 1/gm above any other. 143,738 is no more or less valid than 1/gm.
There is no way to bench test Zkg or Zpg if the Cdyne is kept balanced. There’s no voltage at the junction of the sources in the model whether its center is grounded or floating. There’s no voltage at the junction of the coupling caps on the bench. There’s no current from either of these points to ground. Ergo, you can’t measure the impedance connecting these points to ground. And because that impedance is a part of Zp and Zk, these tests can say nothing about them.
Why don't you engage with the argument in the above paragragh whose conclusion you deny, and try to find flaws in it? Ignoring reasoning is no defense against its conclusion.
Old 9th October 2012, 04:29 PM   #984
On Hiatus
SY's Avatar
Other than all of the actual experimental data. Plug 143,738 ohms into the Thevenin source impedance at either or both outputs and you get the wrong answer.
Old 9th October 2012, 05:12 PM   #985
On Hiatus
SY's Avatar
That might be the most singularly inapt analogy I've ever seen. The Zout = 1/gm model correctly predicts the effects of loading. 6.3V on the heater predicts nothing about the plate. Or was that just a silly debating trick?
Old 9th October 2012, 05:44 PM   #986
And once again, you simply ignore rather than confront an inconvenient argument. You refuse to engage or acknowledge what doesn't suit you.
You will forgive me if I wonder if you are trying to misread what I have said. The fact is that all of the following models are consistent with all of your experimental data. That means that your experiments are incapable of determining which, if any, is correct. Which means you aren't measuring Zpg or Zkg.
Last edited by CPaul; 9th October 2012 at 05:53 PM. Reason: change "zk" to "zkg"; attachment disappeared.
Old 9th October 2012, 09:50 PM   #987
On Hiatus
SY's Avatar
Do you understand the word "predictive"?
Old 9th October 2012, 10:12 PM   #988
On Hiatus
SY's Avatar
By the way, if you eliminate your added Dunsel resistor entirely, you end up with the Figure 2 in my article.
Old 9th October 2012, 10:34 PM   #989
kenpeter is offline kenpeter  United States
Generic triode
Pentodes
Old 9th October 2012, 10:49 PM   #990
Even when identical loads behave non-equal ( due to being on
different push or pull parts of a forward conducting curve ).
Even push the example to extremes of A2 stOOpidity and open
any GNF feedback loops that might push it back into balance.
There just isn't a whole lot damage done by impedance being
locally unequal, when compared to locally forced equal. Its
proven to my satisfaction that there was nothing wrong with
the old unequal impedance Cathodyne that wants fixing.
The worst bent case (aside from DC) has been explored, and
this debate will find no answers at the end of that tunnel.
phase splitter issueHide this!Advertise here!
Phase Splitter Help famousmockingbird Tubes / Valves 16 10th May 2011 09:40 PM
Phase splitter Hojvaelde Tubes / Valves 9 6th May 2011 07:32 PM
phase splitter grungeman91 Tubes / Valves 2 5th May 2011 01:58 AM
Need help on phase splitter guwakzhai Power Supplies 7 23rd December 2010 05:51 PM
Phase Splitter Name Gold_xyz Tubes / Valves 17 21st February 2008 09:48 AM
