#861 |
I can't answer a nonsequitur.
If there's a sucker born every minute, where do the rest of them come from? |
#862 |
Please don't. Just respond to my comment.
"It is error only, and not truth, that shrinks from inquiry." - Thomas Paine |
#864 | |||
#865 |
I'm sure you're chortling about what you consider to be a non-sequitur. Perhaps you'd care to explain yourself so the rest of us can have something to laugh about.
#866 |
Consider symmetry and current cancellation under the specified constraint. You might call it "brittle," but it was successfully applied in some of the most popular and high performing tube amps ever made (Williamson, Dynaco, Heathkit, Eico...).
#867 |
#868 | |
If it were just the differential output impedance that we care about, you should be able to divide up that 11K8 series resistance any way you want and still get the 12K differential output impedance, when you do this the low frequency behavior tells us we are not providing the proper source impedance. dave |
#869 |
I understand why this bothers you.
The best simple answer I can think of is that the Cathodyne is a bit more complex than either a single floating differential source or certainly a pair of ground-referenced opposing sources. That’s one good reason not to think of it in terms of either of these models, because doing so is sure to trip you up. To get an understanding of a circuit, I always recommend doing a full circuit analysis rather than assuming shortcut models. Short of that, you could play around with a lot of simulations, but I still prefer the former approach.
#870 | |
I had that happen is when I used too small of a grid stop resistor on the input of the splitter. And another time I tied too many output tubes in parallel. I increased the grid stoppers on the output which did fix it however, I went back and added a 6sn7 as a buffer between the outputs and phase splitter to provide a better drive signal. |
| Phase Splitter Help | famousmockingbird | Tubes / Valves | 16 | 10th May 2011 09:40 PM |
| Phase splitter | Hojvaelde | Tubes / Valves | 9 | 6th May 2011 07:32 PM |
| phase splitter | grungeman91 | Tubes / Valves | 2 | 5th May 2011 01:58 AM |
| Need help on phase splitter | guwakzhai | Power Supplies | 7 | 23rd December 2010 05:51 PM |
| Phase Splitter Name | Gold_xyz | Tubes / Valves | 17 | 21st February 2008 09:48 AM |
