phase splitter issue
Old 13th January 2013, 08:46 PM   #1041
piano3 is offline piano3  United Kingdom
The inputs are a balanced switched attenuator followed by balanced cathode followers. There is 22k series resistance in each leg of the attenuator with the adjustable element 4k7 at maximum attenuation. Each leg is referenced to ground via the usual 1 Meg grid leak
Old 13th January 2013, 09:19 PM   #1042
CPaul is offline CPaul
Usually the value of a differential system is that noise appearing identically on both legs is subtracted out by the receiver. Using the Concertina as a driver defeats this in two ways.
First, the Concertina’s power supply noise is present virtually unattenuated at the plate, but is attenuated by more than the triode’s mu at the cathode. This means that the differential receiver cannot cancel it out.
Second, stray magnetic fields (power lines, etc.) can induce voltages along signal lines. If the lines are routed similarly, and the line impedances are identical, the induced voltages will be similar and will be mostly canceled out by the differential receiver. But you can prove to yourself that this won’t happen with the Concertina by inserting identical high impedance signals into both legs. The different signals occur because the plate and cathode impedances are quite different.
I think that there are simple and better alternatives, but we discuss those, let’s see if you agree with what I wrote above.
"It is error only, and not truth, that shrinks from inquiry." - Thomas Paine
Old 13th January 2013, 10:15 PM   #1043
Naturally, I agree with all this. I had considered it as an after the fact modification for CD input only-98% of my listening is LP/78's which my main system is totally dedicated to, and as I said, fully differential from cartridge to output. Space is tight, so I was attempting to keep the component count low and additionally, I do not need any significant gain so I was trying to avoid another 2 differentials pairs with their usual CCS's. It may be a better solution to build a separate amplifier for the CD as was my original intention.
Old 13th January 2013, 11:30 PM   #1044
I guess it depends on how far you want to go. I'd be a little concerned about the moderate amount of distortion that any triode I know would present when its P and K were loaded with a resistance as low as 1.5K and it were driven to line levels. But if you're OK with that and you're not concerned with power supply noise or stray magnetic fields, go for it!
Old 14th January 2013, 12:12 AM   #1045
Then we are in total agreement; 1k5 would be a stupidly low load feedback or nay; an input cap would be the better option using cathode bias and the available HT shared more or less equally. I am confident that I can get the HT sufficiently quiet, hum in the microvolt range. As for stray fields.........
Many thanks for your input!
Old 14th January 2013, 12:17 AM   #1046
My pleasure!
Old 31st May 2013, 02:58 PM   #1047
Nothing new, just testing how some posts look.
Old 31st May 2013, 03:00 PM   #1048
Old 31st May 2013, 03:38 PM   #1049
Mosquito is offline Mosquito  Argentina
Mosquito's Avatar
Hi, hope this question is on topic,
what to do when constraints forced You to use sub optimal tubes for the function? I'm thinking specifically in a direct coupled concertina/input stage, made solely of *AX7 tubes. (HT limited to < 320V but very easy output tubes to drive)
"It is less serious than if worst"
Old 31st May 2013, 03:53 PM   #1050
What constraints are you dealing with? Can you be more specific about what you mean by "what to do"?
phase splitter issueHide this!Advertise here!
Phase Splitter Help famousmockingbird Tubes / Valves 16 10th May 2011 10:40 PM
Phase splitter Hojvaelde Tubes / Valves 9 6th May 2011 08:32 PM
phase splitter grungeman91 Tubes / Valves 2 5th May 2011 02:58 AM
Need help on phase splitter guwakzhai Power Supplies 7 23rd December 2010 06:51 PM
Phase Splitter Name Gold_xyz Tubes / Valves 17 21st February 2008 10:48 AM
