phase splitter issue
Old 26th October 2012, 12:17 AM   #1031
On Hiatus
SY's Avatar
Originally Posted by CPaul View Post
First, please review p. 1012, which establishes that model 1 in p. 1016 is the same as the model in Figure 3 of your article. (If you disagree, be explicit as to why. Simply saying that models are wrong is meaningless. Wrong? How? Wrong color? Why, are black and blue no good?)
If you look at that extremely complex non-Thevenin model, then look at my very simple (and experimentally accurate) model and think they're the same, you need glasses. Try counting components- mine, two voltage sources, two resistances. Yours, well, you can count.
The other, simpler models you presented, which I already cited to you, are not the same as mine because they give totally wrong answers for the output voltages.
I think I'll tip my hat at this point and say, "Adieu" until you experimentally show that my model, under the given constraint, does not agree with experiment. Fume away.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th October 2012, 03:05 AM   #1032
kenpeter is offline kenpeter  United States
Driving a push-pull pair of 6L6 into A2 open loop with equal and unequal
models was sufficient challenge to satisfy that both models produce very
nearly the same end result. Any model that says otherwise probably isn't
relevant to the need for this sort of phase splitter anyway.
Cap pumping was the killer, not the subtle effect of huge differences in
AC impedance. Chasing our tails around ridiculous proofs for nothing.
Old 26th October 2012, 03:45 AM   #1033
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
my impression too of this thread.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 26th October 2012, 04:27 PM   #1034
CPaul is offline CPaul
I find SY's reply inscrutable.
What complex model? model 1 is SY's model, model 2 adds one resistor to it, and model 3 subtracts a ground from it!
...non-Thevenin model...
Another SY special: unfounded assertions again. What's non-Thevenin about it?
Unfounded assertions again! This time, in the face of simulations which clearly disprove the claim. Where is the support for "totally wrong answers"? What are the salient differences between the sims I presented and the test results in SY's article?
If after all this time you think I've been challenging your experimental results, you need a semester or two of reading comprehension drills. I challenge the conclusions you draw from a model that are impossible to test given the constraints you have imposed, never your test results. You don't get to exit as cleanly as you hoped.
We have reached the point where we now are living in different realities. Not only do we get unsupported claims, but we are getting ones which seem to defy what is right before our eyes. If no one who has been following this exchange can explain to SY and me each others' fundamental perceptions, then further communication on this topic is indeed useless.
I'd welcome anyone who has been following this exchange to step forward at this point with constructive explanations to one, the other, or both of us.
"It is error only, and not truth, that shrinks from inquiry." - Thomas Paine
Old 27th October 2012, 05:14 PM   #1035
Just because his definition of impedance includes anywhere from 1 to 99%
cross coupled arbitrary noise. By pure coincidence, usually but not always,
happens to quack so muck like impedance, its own mother would not know
where real impedance ends and noise begins...
You seem to forget: Sy's absurd claims are supported, "Because I said so."
Also because the A2 load experiment proved so. No other reality matters...
Old 17th December 2012, 03:07 PM   #1036
Time for me to sum up and put a coda on my posts to this thread. (And there was much rejoicing!)
I built the following familiar circuit and drove its grid with a square wave having a 30mV step:
I also measured the parameters gm ( 8.83mS ) and µ ( 27.6 ) of the triode under the circuit’s operating conditions. I used them in the following analytic expression and models, all of which were developed to predict the plate and cathode voltages of the physical circuit:
The outputs of the circuit, expression, and models appear in the following graph:
Clearly, the all-around agreement is excellent, validating the expression’s and the models’ voltage predictions. Not so much so with the models’ predictions of the low frequency P and K to ground impedances Zpg and Zkg though – in fact, they contradict one another, with values of approximately 1/gm for Model 1 and R/2 for Model 2. Obviously, at least one of the models gets it wrong. And since that one got the voltages right, we have proof that getting the voltages right does not ensure doing so with the impedances. Therefore, there is no reason to believe that either one of them gets it right. So what to do?
Check out the next post!
Old 17th December 2012, 03:11 PM   #1037
Because there has been some controversy regarding the Thevenin theorem in this thread, I’ve turned to the folks who arguably are the ultimate authorities on this matter: The Institute of Electrical and Electronics Engineers. They publish The new IEEE standard dictionary of electrical and electronics terms. In it can be found the following:
Thevenin’s Theorem. States that the current that will flow through an impedance Z’, when connected to any two terminals of a linear network between which there previously existed a voltage E and an impedance Z, is equal to the voltage E divided by the sum of Z and Z’.
Here we have a simple method by which we can determine the impedance between “any two terminals of a linear network between which there previously existed a voltage E and an impedance Z”.
Certainly the Cathodyne can be considered to be a linear network, and among its several “any two terminals” are the plate and ground. When we apply Kirchoff’s laws and Thevenin, it’s trivial to derive
Zpg = [ Rk· (1+µ) + µ/gm ] || Rp
If instead we choose the cathode and ground as the terminal pair, we get
Zkg = Rk || [ (µ/gm +Rp)/(1+µ) ]
Finally, for the plate and cathode, the result is
Zpk = 2/gm / [1 + 2/µ + 1/(gm·R’)] ≈ 2/gm, where R’ = Rp = Rk
There are several take-aways from this:
1. Mr. T. deals with two nodes, not three (P and ground for instance, not P, K and ground);
2. There is no need to keep a balanced circuit balanced while measuring its impedances, and
3. Zpg and Zkg are quite different indeed. In particular, Zkg is just north of 1/gm, while Zpg ≈ Rp >> 1/gm.
And that’s all that needs to be said on the matter.
Old 13th January 2013, 05:19 PM   #1038
piano3 is offline piano3  United Kingdom
I was thinking of simple ways to interface my single-ended CD player with my totally differential main system; is there any reason for not using a concertina phase-splitter with(necessarily) low values, 1k5 say, of R anode and R cathode assuming that the high tension is decoupled with a suitable RC network?
Old 13th January 2013, 08:01 PM   #1039
Actually, that is probably a pretty stupid idea, even considering the feedback; better to use an input coupling cap.
Old 13th January 2013, 08:18 PM   #1040
For the A and B differential inputs of your system, what are the impedances between:
A and B;
A and ground;
B and ground?
phase splitter issueHide this!Advertise here!
Phase Splitter Help famousmockingbird Tubes / Valves 16 10th May 2011 10:40 PM
Phase splitter Hojvaelde Tubes / Valves 9 6th May 2011 08:32 PM
phase splitter grungeman91 Tubes / Valves 2 5th May 2011 02:58 AM
Need help on phase splitter guwakzhai Power Supplies 7 23rd December 2010 06:51 PM
Phase Splitter Name Gold_xyz Tubes / Valves 17 21st February 2008 10:48 AM
Copyright ©1999-2017 diyAudio
