phase splitter issue
Old 24th October 2012, 12:55 PM   #1021
On Hiatus
SY's Avatar
Your posts 972, 986, and 991, which are the only Thevenin models I've seen from you.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th October 2012, 01:22 PM   #1022
CPaul is offline CPaul
Post 1016. The models that you have disparaged as not working.
"It is error only, and not truth, that shrinks from inquiry." - Thomas Paine
Old 24th October 2012, 02:18 PM   #1023
kenpeter is offline kenpeter  United States
Originally Posted by CPaul View Post
Where are the models that don't work? No comments at all? Amazing!
I linked you to the relevant page at Duncan Amps for models.
The 2nd 6l6 model was and is dm6l6.inc. You couldn't find it
the first time, and after I explained where to find, you went
back and did the exact same thing and it still doesn't work.
I never told you to do "exact same thing". You just do what
you do, and its my fault you can't get a result. Coincidence
your arguments against Sy ring much the same? Sy is still
dead wrong (even though he's absolutely right because I
just said so, kinda like what happens at the plate), but you
will never be the one to prove it by whining that we don't
give you stuff.
There is a problem with assumption of correlated independent
causes always giving the same effects. This assumption, and
not absurd models or calculations that may follow, is at fault.
Yet this assumption agrees with real amps pretty darn well,
even in worst realistically conceived case that should poke
big holes, not faulty enough to make a thousand+ posts over.
Old 24th October 2012, 02:38 PM   #1024
Kenpeter, bottom line, I couldn't get the files to work on my PC. I never blamed you for the problem.
If you want to characterize a request for help as "whining" and respond with libelous comments about SY and me in your PM, anyone who might want to ask you for help in the futture should take note.
It's fine that you don't want to help. The vitriol is unnecessary.
Old 24th October 2012, 02:39 PM   #1025
In case of a triode with Mu=100, and the assumption that load behaviors correlate.
What happens at the cathode end is 99% impedance, and 1% arbitrary assumption.
What happens at the plate end is 1% impedance and 99% arbitrary assumption.
I can make you a hybrid where both ends are 50% impedance 50% assumption.
But strangely, it doesn't work any different. My conclusion is that the assumption
was a good one, despite my feelings that it has no merit and ought to be invalid.
Old 24th October 2012, 02:44 PM   #1026
I believe the phase in question was, "You and Sy need to stop smoking crack."
Old 24th October 2012, 02:51 PM   #1027
You got it!
Old 24th October 2012, 03:09 PM   #1028
On Hiatus
SY's Avatar
Hey, it's been at least two weeks!
Old 24th October 2012, 03:21 PM   #1029
SY, I know it's easier to reply to kenpeter than me, but may I redirect your attention to posts 1016 and 1017?
Old 25th October 2012, 09:51 PM   #1030
SY, you seem to be having some trouble responding to p. 1016, and 1017 in light of 1016. Perhaps if I summarized?
First, please review p. 1012, which establishes that model 1 in p. 1016 is the same as the model in Figure 3 of your article. (If you disagree, be explicit as to why. Simply saying that models are wrong is meaningless. Wrong? How? Wrong color? Why, are black and blue no good?)
You can create model 2 from model 1 by adding a resistor of arbitrary value between ground and the sources. Now get rid of that ground and resistor to create model 3. Subject all models to the loads and signals in the square wave test you published in your article. The simulation results (p. 1016) are identical and conform to your test results. So the models aren't “wrong” and “incorrect.” We also see that the ground is non-functional. It plays no part in explaining how a balanced Cdyne works. No great surprise here – there is no ground lurking within a triode.
It makes no sense to defer to models with non-functional components (models 1 and 2) if we have one without them (model 3.) In the absence of a ground, model 3 can even be simplified by combining the sources and resistors to get Burkhart’s model. That model is favored not only because it alone contains only functional components, but because with half the components and nodes of model 1, it would be the choice of Occam (parsimony) and Einstein (as simple as possible, but no simpler.)
But there’s a problem – model 3 states that Zpg and Zkg are a little more than Rk/2 = Rp/2. Actually, all three models contradict one another on that point. But on second thought, it’s really not a problem. There is no experimental evidence available from a balanced Cdyne to favor any of these values. Crafted to reflect only the empirical measurements of a balanced Cdyne, there is no reason to believe that any of the models offers any reliable information about parameters which can’t be measured – Zpg and Zkg.
Neither these nor your model can establish the values of Zkg and Zpg.
phase splitter issueHide this!Advertise here!
Phase Splitter Help famousmockingbird Tubes / Valves 16 10th May 2011 09:40 PM
Phase splitter Hojvaelde Tubes / Valves 9 6th May 2011 07:32 PM
phase splitter grungeman91 Tubes / Valves 2 5th May 2011 01:58 AM
Need help on phase splitter guwakzhai Power Supplies 7 23rd December 2010 05:51 PM
Phase Splitter Name Gold_xyz Tubes / Valves 17 21st February 2008 09:48 AM
