phase splitter issue - Page 100 - diyAudio
Old 10th October 2012, 02:27 PM   #991
SY, kindly specify a test with a balanced Cathodyne that will produce different results when applied to the models below.
Failing that, kindly stipulate that no such test exists.
"It is error only, and not truth, that shrinks from inquiry." - Thomas Paine
Old 10th October 2012, 03:18 PM   #992
SY's Avatar
Those models are incorrect. You might want to squint at them and correct.
If you add a resistor that has no function in the circuit (assuming a correct circuit, not the ones you drew), then a measurement under the stated constraints will indeed show no difference.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 10th October 2012, 03:36 PM   #993
We agree that the "resistor has no function in the circuit" and "a measurement under the stated constraints will indeed show no difference."
That's what I call progress! Now let's examine the consequence of that admission.
If you can't measure it, how in blazes can you say anything about it? Specifically, what is your basis for claiming that the model of which it is a part of is incorrect?
Old 10th October 2012, 03:45 PM   #994
SY's Avatar
The way you present them, they're trivially easy to distinguish. Take a close look and do some analysis.
Old 10th October 2012, 03:55 PM   #995
The answer which is not an answer. I say again:
Old 10th October 2012, 04:01 PM   #996
SY's Avatar
I didn't say anything about it, it's your nonfunctional part. Except in the circuits you just drew, where it's extremely functional and easy to measure, in a bad way.
Old 10th October 2012, 04:53 PM   #997
Of course you've said something about it. You've said that the model it is in is wrong. And within the constraints of balanced Cdyne measurements, I say again:
Last edited by CPaul; 10th October 2012 at 05:05 PM. Reason: replaced old phrase with "the model it is in is "; added "within the constraints of balanced Cdyne measurements"
Old 10th October 2012, 05:14 PM   #998
SY's Avatar
OK, so I take it you didn't look at your own drawing. It does not represent a cathodyne.
Old 10th October 2012, 05:16 PM   #999
That is not an answer. Why can't you answer a simple question?
If you can't measure it, how in blazes can you say anything about it? Specifically, what is your basis for claiming that the model of which it is a part of is incorrect? What is your basis for saying it isn't a Cathodyne?
Last edited by CPaul; 10th October 2012 at 05:22 PM. Reason: added "What is your basis for saying it isn't a Cathodyne?"
Old 10th October 2012, 05:42 PM   #1000
SY's Avatar
Your circuit doesn't represent a cathodyne, so you might want to take a second look at it.
I won't bother saying that again.
Phase Splitter Help famousmockingbird Tubes / Valves 16 10th May 2011 10:40 PM
Phase splitter Hojvaelde Tubes / Valves 9 6th May 2011 08:32 PM
phase splitter grungeman91 Tubes / Valves 2 5th May 2011 02:58 AM
Need help on phase splitter guwakzhai Power Supplies 7 23rd December 2010 06:51 PM
Phase Splitter Name Gold_xyz Tubes / Valves 17 21st February 2008 10:48 AM
Copyright 1999-2017 diyAudio
