| diyAudio Sponsor | ||
Triode Electronics has been offering a 30W, 1250 ohm:8 ohm (actually with 4, 8, and 16 ohms taps plus a 43% UL primary tap). transformer for ages. The primary is rated at a whopping 225 mA. Apparently, they weren't big movers, so Triode recently dropped the price on them quite a bit. It so happens I might actually have a use for something like this, so I bought a couple. First off, this transformer is BIG, weighing in at 11.5 pounds. I did some measurements, and at least with my measuring technique, the transformer primary impedance is more like 1060-1080 ohms (depending on the tap). Inductance is fairly respectable at 11.9H.
The transformers are neatly done (as much as can be done for a big, black chunk of iron). My intentions for these involve something heretical and solid state, but no doubt someone will figure out something that can be done vacuum-wise with these. Running a monster sweep tube UL connected might be an interesting experiment. |
#2 |
Seems like a perfect match for the ten pound power transformer...
#3 |
They ship by Priority only. How much it is, for a pair of such transformers?
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#4 |
They shipped mine in two medium flat-rate boxes, with lots of padding.
#5 |
Thanks, I am in for SE experiments with new concept of power amps.
| Transformer needed or "solid state guy needs help from tube guys" | quasi | Tubes / Valves | 9 | 15th January 2010 11:56 AM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Single-ended-series amp with a "1 winding" transformer | tubee | Tubes / Valves | 27 | 17th September 2007 07:15 PM |
| Wanted: Hammond 125E or other "universal" output transformer | Spasticteapot | Swap Meet | 2 | 13th July 2007 10:29 PM |
| Autocostruire/Autodigit "Class T" PSU - transformer question | geaugafletcher | Power Supplies | 0 | 10th June 2006 04:19 PM |
| Page generated in 0.07280 seconds (72.65% PHP - 27.35% MySQL) with 11 queries |
