| diyAudio Sponsor | ||
Dose anyone hear know what kinde of socket the German LS 180 Triod uses.
The pins on the Tube are 2mm thike, its clearly a 4-Pin Socket but not the same as a 811A or a GMI83V the pins are much narower. so dose anyone here know what kinde of socket i have to use on it. hear is a link to a tube site were there are mor infos on the tube, but not on the soket : LS 180, Tube LS180; Röhre LS 180 (LS180)unfortunetly the datasheet: http://frank.pocnet.net/sheets/043/l/LS180.pdf dosent say the socket type. so if anyone here knows what socket i need for the LS180 pleas send me a mesage. |
#2 |
Don't know if you have seen this: Wurzburg rep! Makes an interesting read. It does show the socket used for the LS180. What do you intend doing with it? Cheers Matt. |
#3 |
thanks for writing, no i havent seen that. and thanks. i will keep an eye out of other replys on this post.
| Tube socket purchase | TubeMack | Tubes / Valves | 8 | 22nd August 2010 02:59 AM |
| Tube socket does not fit tube | WRyan | Tubes / Valves | 18 | 20th January 2009 01:41 AM |
| tube socket sale | tubesocket | Vendor's Bazaar | 21 | 11th November 2008 12:36 AM |
| Help on tube socket | dung0981 | Tubes / Valves | 6 | 5th August 2006 08:31 AM |
| Tube socket wanted. (help where) | Hojvaelde | Tubes / Valves | 3 | 21st June 2005 11:29 PM |
| Page generated in 0.07785 seconds (69.55% PHP - 30.45% MySQL) with 10 queries |
