6550 Users Beware...
Old 12th August 2003, 12:02 PM   #1
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Exclamation 6550 Users Beware...
This morning I received an e-mail from Bruce Rozenblit (Transcendent Sound).
Apparently the metal base version of the Svetlana 6550s have this base connected internally to pin # 1 which in turn is connected to pin # 3; the anode/plate.
This obviously exposes any plate voltage present so touching both the base and chassis can present a lethal hazard.
The original mesage can be read here:
MESSAGE BOARD.
Please follow the advise given by Mr. Rozenblit and make sure no plate voltage remains before you pull out the offending tubes.
Frank
Old 12th August 2003, 12:18 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Pin 1 should be connected only to the external shield.
I just checked some Sovteks (which are accutely similar to some Svets), and this is the case ( They're OK).
Svetlana 6550 datasheet
I think this can be a warning to us to always ground pin 1 in constructions using 6550's. With this done, there would be no safety hazzard, just a blown fuse.
Old 12th August 2003, 12:45 PM   #3
fdegrove's Avatar
Thanks, John.
I don't have any 6550Cs handy so I couldn't check.
So, I assume the warning was only sent because on the Transcendent Tube Analyzer octal socket pin #1 and # 3 are tied together.
Frank
Old 12th August 2003, 03:29 PM   #4
dhaen's Avatar
Frank,
That is a thought. The way it's worded, it could be the valves or the analysers that are at fault.
Old 12th August 2003, 05:06 PM   #5
Positron is offline Positron  United States
Default 6 analyzers
I think you are right. Looks to me like the 6 analyzers are at fault with pins 1 and 3 tied together at the socket.
Old 1st January 2005, 06:30 PM   #6
rdf is offline rdf  Canada
rdf's Avatar
Two year bump. Hi fdegrove, do you use the Transcendent Tube Analyzer? Kindly spare an opinion on it? I caught the bug.
Old 1st January 2005, 07:45 PM   #7
fdegrove's Avatar
No, I do not but the problem isn't pertinent to this analysizer.
Frank
Old 1st January 2005, 09:08 PM   #8
rdf's Avatar
It was at the time. TA shipped a half-dozen analyzers with the problem tube. The field repair notification was how I found the thread. Thx for the reply.
6550 Users Beware...Hide this!Advertise here!
Beware of big bass sam9 Everything Else 1 4th September 2004 05:49 AM
Beware!!!!! Fake Sankens mcp Solid State 14 30th May 2003 07:25 PM
