diyAudio Sponsor
Old 13th May 2011, 06:02 PM   #1
neskor is online now neskor  Serbia
Default DHT for 300B problem
Hello
I just finished DHT for 300B, but when I start on output I have 8.75V for 10 sec. and than goes to desired 5V.
Can I leave like this or it will damage 300B?
Any one have idea how to solve this problem?
Old 13th May 2011, 06:27 PM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
That's about the opposite of what you want to do. Applying 8.75 V to a dead cold filament will cause a lot of current to run in the filament, thus, causing a thermal chock. That's not nice...
I wonder if it has to do with the fact that you have two control loops in your circuit. One that controls the voltage across the filament, the other controls the current. I would eliminate the voltage control loop and just program the current to 1.4 A. You could make it adjustable so that you can adjust for 5.0 V across a hot filament.
~Tom
Old 13th May 2011, 06:51 PM   #3
astouffer's Avatar
The schematic says a maximum of 7 volts input and you get 8.75 out? Perhaps you are overloading it?
Old 13th May 2011, 06:53 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It looks very strange. You should have slowly increased voltage between + and - signs for filament connection, as drawn.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 13th May 2011, 07:01 PM   #5
the_manta's Avatar
Why not taking a dead simple regulator/pass transistor ? The PSU in the pic is over engineered in many ways. There are so many parts, I could build another amplifier from that
Old 13th May 2011, 07:24 PM   #6
Wavebourn's Avatar
Here is my example of more than adequate voltage regulator:
Old 13th May 2011, 09:09 PM   #7
I found what was a problem.
Value of capacitor C8 determine time to reach desired voltage.
So I put 10uF and now is working like a charm
HQ-DHT (All tube DHT amli) 26-45-2A3 quanghao Tubes / Valves 33 9th November 2011 07:27 PM
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 49 30th April 2007 12:25 AM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
My audionote Kit one have problem on 300B cathode terminal ramnmic Tubes / Valves 4 13th January 2005 06:56 AM
Page generated in 0.09942 seconds (72.41% PHP - 27.59% MySQL) with 11 queries
