| diyAudio Sponsor | ||
Good morning everyone,
Can anyone offer some ideas for a "red board" add-on phono/RIAA pre-amp? Perhaps one that would have multiple inputs for perhaps tuner, phono, tape, cd, etc.... Any decent compactrons that might fit the bill??? Thanks, Ray |
#2 |
Lemme see if I get the question right. You're looking for a RIAA preamp with a low-gain input for CD, tape, etc. that uses Compactrons?
I suggest looking at RIAA preamp designs that use tubes which are available as Compactrons. There's one here: My own RIAA tube preamp One could follow that up with a cathode follower rather than the source follower used. You could then switch the CD, etc. in at the input to the source follower. Not saying that's the best design, I'm just throwing ideas at you. ~Tom |
#3 |
There is a compactron that is 3/2 of a 12AX7. I am 1200 miles away from my notes but it is a 6_10 (6C10 maybe) and it was used in Ampeg guitar amps among other things. I question this route since the compactron tubes are only available from one or two manufacturers, and 12AX7's are available everywhere in mulltiple flavors. A tube phono stage will usually need some tube selection for low hum, noise, and microphonics.
My current phono stage is made from sand (a single National Semi chip) and fits inside the turntable. The line stage it feeds uses a 12B4 feeding several mosfet followers. That gives me a few independent outputs for running several amps without cable swapping. The input switching is via tiny relays.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#4 |
Well here's what I came up with compactron wise:
6AY11 - Twin Diode - Twin High-Mu Triode - Close to the specs of the 12AX7 6C10 - Triple High-Mu Triode - Same specs as the 12AX7 - What can I use the addtional triode for? 6Q11, 6K11 - Twin High-Mu Triode - Medium-Mu Triode - Same specs as the 12AX7 - What can I use the addtional triode for? The circuit I was looking at is the circuit from the RCA tube manual. (I attached a PDF) If I did use one of those triple triodes, any thoughts what to do with the additional triode? Thanks, Ray Last edited by rsumperl; 14th May 2011 at 12:39 PM. |
#5 | |
The RCA circuit is intended for mass market console stereos of the 50s and 60s, not for high quality audio.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 |
So what about using the two Hi-Mu Triodes as the "amplification" for the magnetic cartridge then feeding into the Med-Mu Triode as a cathode follower? Looking at the RCA circuit, what would you change to perhaps make it better?
Thanks, Ray |
| How Can I connect A Balanced RIAA Phono Pre-Amp to a Phono Plug amp input | jmartinbaugh | Analogue Source | 3 | 25th April 2011 01:24 PM |
| HI-END Phono Amp - QSXM3 RIAA board | rclourenco | Analogue Source | 0 | 8th June 2009 04:57 PM |
| phono pre RIAA 2001 | oldeurope | Tubes / Valves | 5 | 8th May 2008 09:05 AM |
| how build usb phono pre riaa | tekton364 | Analogue Source | 2 | 28th September 2007 08:50 PM |
| Circuit board for phono pre-amp | peterb | Analogue Source | 1 | 4th February 2004 04:56 PM |
| Page generated in 0.10020 seconds (74.19% PHP - 25.81% MySQL) with 11 queries |
