i finally got around to fixen it - diyAudio
Old 12th August 2003, 05:39 AM   #1
karma is offline karma  Canada
karma's Avatar
Default i finally got around to fixen it
so thats what it sounds like when its not worn out not to shabby
the phone stage on this old trio amp was in bad shape popping
hissing and a lot more. found out the sockets on the phone stage
had a lot of heat damage. i finally got around to doing it. the amp even has a headphone jack wierd
anyway heres some pics
not finished still gota pic up new output tubes and sockets for em
and yes the value of the amp does go down if you change parts but i would like to use this one
Old 12th August 2003, 05:41 AM   #2
karma's Avatar
Default .
old sockets with shields
Old 12th August 2003, 05:42 AM   #3
karma's Avatar
Default .
Old 12th August 2003, 05:43 AM   #4
karma's Avatar
Default z
z
Old 12th August 2003, 05:45 AM   #5
karma's Avatar
Default last one
have a good tuesday guys later
Old 12th August 2003, 05:58 AM   #6
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Remember to change all the old coupling caps if they are wax paper jobs; they tend to go bad and fry the output tubes...
Otherwise looks really nice. Bet it sounds good too!
A30 - Finally! gema Pass Labs 41 29th June 2009 05:32 PM
finally getting going Spica Introductions 1 20th January 2008 02:57 PM
finally...I am able to say hello to everybody and everyone. groov Introductions 3 28th August 2006 09:44 PM
Finally jpb200 Multi-Way 2 26th May 2004 01:58 AM
Finally, almost done with first IGC officeboy Chip Amps 3 11th February 2004 04:24 PM
Copyright 1999-2017 diyAudio
