| diyAudio Sponsor | ||
In order to complete a school work about amplifiers, I need a picture of a power amp at work where you can see the electron flux. I google'd but didn"t find any, could you deliver one if you own it ? Thanks in advance A |
#2 |
How should it look like ?
Should it be some kind of drawing ? (like that: File:Elektronenroehre real.png ? Wikimedia Commons) You can't make the electron flux visible in a vacuum tube unless you put some kind of gas into it. |
#3 |
Then the gas will stop it working. Electrons are invisible. Apart from the heater glow and possibly a front panel light, a working amplifier looks exactly the same as a non-working amplifier.
#4 |
Yes I may have been a bit fast by saying electrons, I should have simply said a picture of a tube "working", if it is visible. I found this picture on wikipedia :
But it isn't really what I imagined, I had rather thought about a sort of blue ondulation, a bit in the same way as a plasma lamp (but not as heavy of course). Edit : I just remembered about Thyratron (Video), can't we have a similar phenomenon in audio applications ? Last edited by axhan; 13th May 2011 at 12:08 PM. |
#5 | |
You could try to modify an tube(injecting some neon gas in it) but that's no easy task. |
#6 |
#7 |
The blue glow seen in some good tubes is fluorescence of the glass. Nothing to do with gas. I'm not sure if the OP wants a genuine picture of a tube working (which will not show much) or some 'artistic' picture giving a false impression. Is your project for arts or science?
#8 |
300B Tube
Frank |
#9 |
Not at all, the purpose is to show that, in opposition with preamp tubes where you cannot see anything except heating, some power tubes have some visual effect and a picture illustrating it would be nice.
The picture which was just posted by Frank Berry fits fine indeed |
#10 |
Franks photograph is quite amazing. I've never seen a photo where one could so clearly see the image of the plate structure projected onto the surface of the glass. That's really neat.
I've always liked this illustration of a beam power tube. I believe it came out of one of the old RCA handbooks. It shows the electron flux fairly well, I think. Too bad it's only an illustration, and not an actual photo. The tricky thing is, you can't really see the actual electrons themselves. They're much too small.
| Clear picture picture of KSS-273B | eledora | Digital Source | 0 | 27th October 2007 01:10 PM |
| Perplexed by 5AR4 Tube Socket? Picture Included | ted777ted | Tubes / Valves | 4 | 26th September 2005 10:04 PM |
| heater voltage of scope picture tube ? | Bernhard | Parts | 1 | 18th September 2005 03:03 PM |
| Picture of my first tube amp | FrankDIY | Tubes / Valves | 15 | 25th October 2002 09:09 PM |
| Page generated in 0.10577 seconds (76.12% PHP - 23.88% MySQL) with 11 queries |
