diyAudio Sponsor
Old 9th May 2011, 01:20 AM   #1
yero is offline yero  United States
Default 12bh7a
Tube data indicates the tube is used for a tv vertical deflection amplifier. Can each section be used as a line level stage with similar results as the 12b4 which is also used as a tv vertical deflection amplifier. If so what would the plate and cathode resistor values be.
Old 9th May 2011, 04:34 PM   #2
kevinkr's Avatar
This tube is similar to the 12AU7A/ECC82 - take a look at typical operating conditions for that tube..(Any RCA tube manual) Much higher mu (20) and rp than the 12B4 incidentally. I used them extensively as long tailed pairs in some of my early commercial PP designs.
www.kta-hifi.net
12BH7A driver stage help stein2 Tubes / Valves 0 21st October 2010 07:33 PM
12BH7A in common cathode Skorpio Tubes / Valves 7 29th August 2010 06:04 PM
Question - Closest Russian Analog of 12BH7A LinuksGuru Tubes / Valves 3 22nd July 2009 10:04 PM
Page generated in 0.07682 seconds (67.21% PHP - 32.79% MySQL) with 10 queries
