6P3C-E Datasheet help
Old 7th May 2011, 07:33 PM   #1
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Default 6P3C-E Datasheet help
Can anyone tell if it specifies forced cooling on this datasheet?
''GSTube.com''. Tubes, sockets etc. Parameters and characteristics 6P3C-1
I see that it says 2 x 20 W plate dissipation, but I'm skeptical that this envelope can handle 40W combined plate dissipation + G2 dissipation and filament power. It's small; comparable in size to common 20W rated tubes. I recently obtained a few boxes of mixed parts which contained a pair of these. Thinking of doing a pair of single output tube PP amps.
Old 7th May 2011, 11:06 PM   #2
LinuksGuru is offline LinuksGuru  Europe
Everything is correct, 2 x 20W
Old 8th May 2011, 02:01 PM   #3
SVStube is offline SVStube  Ukraine
Not very reliable tube, make better use of its military analogue ГУ-19 (GU-19)
Old 8th May 2011, 09:27 PM   #4
azazello is offline azazello  Bulgaria
azazello's Avatar
This tube /from link/ is 6R3S /6Р3С/. 6P3C-E /6П3С-Е/ is mono beam tethrode, close to 6L6.
Old 8th May 2011, 11:50 PM   #5
Jeb-D.'s Avatar
My mistake, I meant 6P3C-1, not 6P3C-E. The link is for the tube I was referring to.
So I've heard, but to my knowledge the Priboy is the only amp that has used this tube. I wonder how much of this tubes bad reputation is the fault of the amp design and how much is the fault of the tube itself.
GU-19 looks interesting. Seems like a direct swap. Maybe I'll run the 6P3C-1 for now and then replace them with GU-19 once they fail. It appears that GU-29/829B would also interchange if the socket were changed with it.
Old 9th May 2011, 05:21 AM   #6
GU-29 is very similar to GU-19, but I like more. See circuit diagram with the article http://lynxaudio.narod.ru/articles/Lynx_VTA39.pdf. Very interesting amp.
You can use the GU-19 (6R3S-1)
Old 9th May 2011, 05:24 PM   #7
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
As I get it, the 6R3S is very unreliable, whereas the transformers in the Priboi amp are overrated. The O/P trannies also are supposed to be used for the 4-tube 75W version of the amplifier.
THAT sounds interesting.
I have a spare 6R3S that I want to use for a simple two tube amp in the future.
Be careful when using/transcribing cyrillic letters as especially the Russian equivalent to 6L6 can easily be mistaken for the dual tetrode used in the Priboi amp.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 22nd August 2011, 03:25 PM   #8
tchiwam is offline tchiwam  Finland
Blast from the past, I still have 8 channels up and running, one of the amps has many, many hundred of hours on it and it still goes on. I used the GU-19 for a while and it works well at around -10V bias.
I think the most important is to keep the priboi bias really well balanced.
6P3C-E Datasheet helpHide this!Advertise here!
Datasheet shon35us Chip Amps 3 9th March 2009 03:10 PM
Looking for datasheet satelitis Tubes / Valves 3 9th December 2005 08:20 PM
Datasheet help Stocker Parts 0 10th March 2004 01:36 PM
Datasheet Piersma Digital Source 3 29th January 2003 07:49 PM
Need datasheet Michael_N Digital Source 5 21st January 2002 11:07 PM
Copyright ©1999-2017 diyAudio
