| diyAudio Sponsor | ||
Generally cathode resistors are bypassed in SE stages, but what other options are there?
a) Partial bypass - split the cathode resistor into two resistors and bypass one of them. In this case the upper part or the lower? What ratio of bypassed/unbypassed? b) Combination bias - combine grid bias with cathode bias (bypassed or not) Could anyone talk about these options and give examples? I'm thinking about a 300b output in a SET but it's a general principle. I'm wondering if any of these options might have some advantage over a simple bypassed resistor. Andy |
#2 | ||
In addition, you get the adjustability of fixed bias and the safety of cathode bias. |
#3 |
While we're on the subject, how do you calculate the value of a cathode bypass cap for a 46 where the plate (375v) is loaded with an interstage transformer (Hammond 126C) and there's 135v on the grid from the direct coupled previous stage? Cathode resistor is 14K. Current is around 10-12mA
andy |
#4 |
The LF point is set by the bypass capacitor reactance being equal to the parallel combination of the resistance looking into the cathode (roughly 1/gm but modified by the anode load for a triode) and the cathode resistor. In your case the resistor is so high that you can ignore it. Just work out the cathode impedance. I can't remember the exact formula but it is something like (1/gm) + (anode_load/mu).
#5 | ||
For the most part, cathode degeneration resistors can be set to be equal to the reciprocal of yf, or determined empirically: Set up the tube with the necessary cathode resistance to establish the Q-Point. Connect a variable resistance in series with a large capacitor, and parallel the RC series circuit with the cathode resistor. Adjust the variable resistor until you get the results you're looking for. Remove, and measure the resistance. The parallel combination of the cathode resistor and the settingof the variable resistor becomes the portion of the total cathode resistance you'd use for degeneration, the rest being bypassed. Quote:
#6 |
Andy,
I'm a big fan of combination bias, especially in the case of the 300B. An unbypassed cathode resistor of 150 Ω does 3 things for you: a reasonably convenient test point for setting the "idle" current is available, some protection against runaway (a known issue with "fixed" bias DHTs) is provided, and (courtesy of degeneration) the tube is linearized. Remember, even Harvey Rosenberg was honest enough to state the 300B puts on a show. IMO, the price paid in reduced gain and increased O/P impedance is not excessive.
Eli D. |
#7 |
Hello Eli,
Very useful - did you work out 150 ohms empirically by listening or is it a convenient value? What kind of bias supply did you use? I'd forgotten Ultrapath and wonder if I should also try that. Andy |
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 05:26 PM |
| 300B Cathode Feedback + Cathode Bias | korneluk | Tubes / Valves | 13 | 7th January 2009 08:07 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 01:30 AM |
| UL to triode mode conversion on cathode bias amp-different cathode resistors needed? | bigwill | Tubes / Valves | 6 | 30th December 2007 12:37 AM |
| Partial cathode bypass to effect a treble boost. | Shoog | Tubes / Valves | 4 | 22nd May 2007 07:34 PM |
| Page generated in 0.11623 seconds (81.58% PHP - 18.42% MySQL) with 10 queries |
