Low voltage 12AU7 (19J6) -- re "starving"
Old 29th January 2013, 09:24 PM   #21
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by tubelab.com View Post
series string heater circuit
I came across the 20EZ7 when they were about a buck each. No more.
Old 30th January 2013, 07:59 PM   #22
jackinnj's Avatar
You could use a bunch of other tubes -- the temptation would be to put a resistor in the filament supply but the current at turn-on is pretty huge. In the case of a 12AX7 the cold resistance is about 13R.
If you put a DN2540 in the filament line, however, you can limit the turn on current and set a value which is appropriate:
Old 1st February 2013, 03:39 AM   #23
jackinnj's Avatar
Finished:
Low voltage 12AU7 (19J6) -- re "starving"Hide this!Advertise here!
low voltage "high gain" amp razorrick1293 Tubes / Valves 32 8th April 2011 04:45 AM
Advice Needed: "Flabby" Amp Low-End independentexile Tubes / Valves 2 23rd October 2010 04:27 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 7th September 2008 12:35 AM
Headphone amp - low Z load and ... "echo" yagoolar Headphone Systems 12 31st March 2007 12:13 AM
Copyright ©1999-2017 diyAudio
