| diyAudio Sponsor | ||
The Crimson Dynamo
G'day fellow tube fans,
Does anybody have any experience with Pioneer SA-810 tube amps ? Has anyone rebuilt or recapped one ? Any photo's ? How about a parts list. I have a schematic but it ain't too informative. ![]() Thanks & cheers, Andrew. |
#2 |
Andrew,
I've done a restoration on one. As well as the elctrolytic caps in the power supply these things often suffer failures due to the coupling caps between the phase splitter and output tube grids going leaky. If these caps have "Suzuki Oil" on their labels then be VERY suspect of them. These were used widely in Japanese Amps of that vintage and nearly always cause problems. I usually just rip them all out (the ones labelled Suzuki Oil) and replace them with modern polypropylene caps of the same value. I have a Hi Rez scan of the original Pioneer circuit diagram which I can send to you if its likely to be of use. PM me if you need it. Much too large to post here. Also specify if it is the SA810 or SA-810S. I have Schematics for both. Cheers, Ian |
#3 |
The Crimson Dynamo
G'day Ian,
There are no PIO caps in amp. I intend to put some in though.Maybe Sprague,West Caps,Chicago or some Russian military ones etc... I'm going to replace all the electro's - I can't find anyone selling the large can power supply caps though.(Only small ones which don't look very impressive). Do you know if there is much of a difference between using PIO caps and Orange Drops. I have uploaded some pics of my amp I took with my phone in "file attachments" so you can see the caps (and the rest). Hope they work. The amp is actually pretty gutsy and gets loud on 3 but there is a little distortion and as far as I'm concerned it needs a good "tune-up".(Cap overhaul) Thanks for replying to my thread Ian, I like to arm myself with ideas and experience that other people had. Regards & cheers, ![]() Andrew. |
#4 | |
Anyway I digress - good luck with the rebuild Brgds Bill |
#5 |
The Crimson Dynamo
He he he he he ! That made me laugh.
![]() Ok Bill, a lovely anecdote !!! Ah ~ what is Sy's red light district ? Thanks for the info. Cheers, Andrew. |
#6 |
The Crimson Dynamo
Here are the pics of my Pioneer SA-810.
#7 | |
The Red Light District - another PP EL84 amp Also before you ask..... EL84 Amp - Baby Huey Last edited by Soonerorlater; 5th May 2011 at 11:26 AM. |
#8 |
The Crimson Dynamo
This amp has been relatively finished. I have replaced nearly every cap - electro's incl' and almost every resistor for good measure (NOS carbon comp).
All the signal caps (all of them waxy brown types) have been replaced with the Rusky Millitary K40Y-9 and K42Y-2 caps. The volume pot was off on it's own mission, It sounds so good it is a bit spooky ! Check out the mortar shell PIO's in front of the output trannies (K40Y-9), there was no room for them underneath and had to do a little modding to fit them on top. Looks pretty darn "killer". Glad I did this .Sorry I've taken so long to reply to this. (My Sansui 1000A is kicking some serious butt now too). Cheers |
#9 |
The Crimson Dynamo
Sorry, I am unable to post any pics. The options have changed (not giving me the option). Bastard !
#10 |
The Crimson Dynamo
| PIONEER SA-810 Tube Amp Schematics | refference | Tubes / Valves | 15 | 24th May 2012 04:03 AM |
| My whole amp mod and rebuild log Pioneer SA-7300 with 26 pics! | rg12 | Solid State | 18 | 27th April 2012 10:35 AM |
| Info for Pioneer SA-810 tube amp | Archibaldy | Tubes / Valves | 2 | 18th April 2011 10:40 AM |
| Wanted: Pioneer sa-810 schematic | Raphael Shaw | Tubes / Valves | 15 | 17th April 2011 01:05 PM |
| Pioneer sa 9900 | David Robert | Solid State | 1 | 15th April 2005 06:52 AM |
| Page generated in 0.12333 seconds (81.14% PHP - 18.86% MySQL) with 11 queries |
