When can screen voltage be higher than plate???
Old 2nd May 2011, 01:54 AM   #1
rsumperl is offline rsumperl  United States
rsumperl's Avatar
Default When can screen voltage be higher than plate???
Hello everyone,
Looking at the 12BY7A, how is it that the screen can be higher than the plate? My understanding has always been the plate is higher.
Thanks,
Ray
File Type: gif harmon_kardon_citation_5_schematic_diagram.gif (32.8 KB, 378 views)
Old 2nd May 2011, 02:36 AM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Typically, receiving tubes are safe with plate voltage higher than 30-100V, or 1/4 to 1/2 of Vg2. Transmitting tubes are typically higher, of course.
As shown, the tube can never draw excessive screen current due to the large series resistance. However, this affects distortion and makes the input impedance particularly bizarre, because as the tube goes into saturation, screen current shoots up, screen voltage falls and miller effect comes into play on Cg1g2. Effectively, the amplifier slows down as it goes into saturation, which is undesirable.
I wonder why the designer chose 12BY7 over a more suited pentode like 6AU6, or a triode such as 6AV6.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 2nd May 2011, 02:55 AM   #3
Eli Duttman is online now Eli Duttman  United States
Considering the designer was Stu Hegeman, you can be certain he had good reason. An obvious fact is the high gm of the 12BY7. That high gm provides resistance against slew limiting. The Cit. 5 employs Mullard style circuitry and a good deal of GNFB is present. Slew limiting is always a concern under those conditions. A possible tweak to the Cit. 5 is employing an ECC99, instead of a 6CG7/6FQ7, as the LTP. Stu didn't have access to the '99, with its high gm, back in the 1960s.
IIRC, the graphic is not error free. Check Jim McShane's site out for info. on tubed H/K Cit. units. Jim's expertise in this area is unrivaled.
Eli D.
Old 2nd May 2011, 02:56 AM   #4
HollowState is offline HollowState  United States
HollowState's Avatar
I believe your schematic in incorrect. Here is a partial scan of an original HK document. Notice the voltage chart in the lower left. It calls for 145v on the plate and 140v on the screen. And the screen bypass capacitor is in the wrong place on yours as well.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 2nd May 2011, 03:38 AM   #5
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
The 6AV6 is a real pipsqueak with a Pd= 500mW. Not much drive capability there, and the 6CG7 LTP probably isn't gonna present a 6AV6 with a very friendly load.
The 12BY7A is a real beast, having ratings more like a power pentode, as it was intended as a color TV video amp. As such, it likes high voltages (no shortage of that in a color TV) and the plate characteristics in the spec sheet are plotted against a screen voltage of 180Vdc, though it has a nice looking plate characteristic down around the -6.0V region (where this seems to be operating: Ip= 6.0mA). Dropping screen voltage and bias would keep the plate current the same, and get the screen voltage under the plate voltage where you want it.
6AU6's seem to be at their best with Ip= ~3.0mA, so may have been lacking a bit in the drive department, and perhaps y(f) too, despite working the 12BY7A at such a low plate current?
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 2nd May 2011, 11:26 AM   #6
Bandersnatch is offline Bandersnatch  United States
Sure he did, it was type number 5687....
FWIW, the Citation II also ran the 12BY7 with its g2 higher than its plates.
cheers,
Douglas
the Tnuctipun will return
Old 2nd May 2011, 11:34 AM   #7
DF96 is offline DF96  England
Could you briefly explain why?
Old 2nd May 2011, 06:17 PM   #8
Almost every text on hollow state tells you that tubes not driven into grid current require just voltage, not current. That isn't just an over simplification: it's just plain wrong. Even if Vgk never goes positive, the grid still had capacitance associated with it: Cgk + Cmiller + Cstray. The grid won't see the true signal level until that capacitance is fully charged, and it takes current to charge a capacitor. The faser you want that capacitor to charge, the more current you need to pump into it.
Take a look at this loadline. The driven stage will be demanding the most current when the 12BY7A is least able to supply it. When the plate voltage comes up, the potential difference across the plate resistor goes down. The ability to supply current to the load is:
I= (Vpp - Vplate) / Rp
That's why it's a good idea to make sure the Q-Point current is at least five times the peak current at the highest frequency of interest, and why the 12BY7A was designed in the first place: as a color TV video amp. Even though you try to make CRTs in such a manner to minimize internal capacitance, you can't completely eliminate it. Since you need to drive the cathodes of the color CRT at a max rate of 4MHz, it takes a pretty stiff current to charge that capacitance, even if it's held to picofarads.
If you use a tube with a high y(f) -- like the 12BY7A -- you can get the gain and the linearity with a much smaller plate load. The smaller plate load, the more current reserve.
This is something that gets overlooked a lot in audio designs. No way can something like a 12AX7 drive the grids of an audio power final, and keep up with the current demand. If there isn't enough current, the control grid(s) of the final(s) won't track the signal. That's the slew rate problem.
www.dolphin-hsl.com
Old 2nd May 2011, 07:15 PM   #9
Cassiel is offline Cassiel  Libya
How about driving the grids of two KT88's in parallel? Yes, I wouldn't do it but Jadis did.
Old 2nd May 2011, 07:46 PM   #10
So Mullard were completely wrong to drive a LTP phase splitter with a pentode with such low gm and drive capability as an EF86, and then drive a pair of EL34s from this ECC83 splitter?
I accept that if you think you need a low anode load but still want high stage gain then a high gm valve is necessary. A low anode load may be necessary at this point if the LTP is biased into the grid current region - an easy way to do this is to run the LTP at too high a current (perhaps in order to 'drive' the output stage) or too low quiescent anode voltage. The design being considered here avoids that problem, fortunately. However, it has a large capacitor at the pentode anode (430pF) which creates the problem I thought we were trying to avoid. A 6CG7 LTP should not be particularly hard to drive so I am puzzled why such a low impedance input stage was chosen.
When can screen voltage be higher than plate???Hide this!Advertise here!
Output Pentode Screen at half Plate voltage Andrewbee Tubes / Valves 32 3rd May 2012 12:41 AM
plate and screen voltage screenplate Tubes / Valves 9 10th May 2010 05:11 AM
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 09:57 PM
Cap voltage can I go higher captaink Digital Source 3 3rd November 2007 09:56 PM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 05:01 AM
