| diyAudio Sponsor | ||
![]() I received my XPWR035 from Edcor yesterday and I was trying to hook it up with my finished tubelab SSE PCB. But I noticed that brown/white-brown/brown wires are sticking out along with black/black wires from the primary side. While on their webpage the picture as well as schematic shows that brown wires should be coming out along with red and yellow wires. Did Edcor worker(s) make mistake making this power tx? FYI Brown wires are supposed to 3.15v/3.15v secondary windings that go towards speaker output section on PCB. If you own this transformer then please tell me which side your brown wires are on.. EDCOR Electronics Corporation. XPWR035-120 Last edited by imnewbie; 30th April 2011 at 05:18 PM. |
#2 |
I do not own this particular power transformer, however I do have other Edcor transformers. One of them has the filament wires coming out on the same side as the primary. Don't be concerned about this because sometimes they are just build this way. Electrically it's the same transformer.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
Ohm it out. While i dont own that one, i have one were the whitebrown (heater ct) comes out of the primary side.
Get a multi meter. brown wires should be connected, as should all the other colors. No colors should connect with each other, other then the ct's of each color. Or you could just hook up (fused of course) to the wall and test all your leads before you hook it up to your shiny new $500 unit. switch the multi meter to ac; red should read above 740 brown should read over 6 yellow should read over 5 |
| Edcor XPWR059 power problem | webby | Tubes / Valves | 15 | 16th April 2011 07:53 PM |
| Power Tx Myth? | M Gregg | Tubes / Valves | 47 | 2nd September 2010 11:25 AM |
| edcor power trans BN | mrrach2 | Swap Meet | 0 | 22nd September 2009 04:40 AM |
| help wiring these power tx | riotubes | Parts | 14 | 16th November 2008 01:06 AM |
| Edcor Power Transformer | rudy129 | Swap Meet | 0 | 5th December 2007 01:49 PM |
| Page generated in 0.07934 seconds (75.43% PHP - 24.57% MySQL) with 10 queries |
