Can I balance a diff stage like this?
Old 27th April 2011, 10:08 PM   #1
martyh is offline martyh  United States
Default Can I balance a diff stage like this?
Possibly another really silly question by yours truly but…
Can I balance DC in a stage like this by making Bias 1 and Bias 2 adjustable assuming that there will be enough voltage across the CCS to make it work?
Thanks,
Marty
Old 27th April 2011, 10:24 PM   #2
DF96 is offline DF96  England
Yes. Better to have one adjustment, but you can do it with two.
Old 27th April 2011, 10:25 PM   #3
lineup is offline lineup  Sweden
lineup's Avatar
Usually you put a suitable linear potentiometer between cathodes.
And the wiper connects to the current sources.
This will divide the current to the triodes according to potentiometer turn.
lineup
Old 27th April 2011, 10:27 PM   #4
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Yeah, but why would you want to? It's a differential, and so there is no need to adjust bias on both sides. One side will do (see attached). In this preliminary design, DC balance is provided by a small +/- supply.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 27th April 2011, 11:52 PM   #5
Thanks again to all of you.
Miles and DF, Making only one side adjustable makes sense. Thanks for the suggestion. As a follow up any thoughts on how much adjustment I would need for a typical medium mu twin triode? Would say setting the fixed side to get 20% of the required bias and setting up the adjustable side to do between 30% and 10% be a reasonable starting point?
Lineup, I proposed something like that a while ago but as I understood the replies using resistors on the cathode side would screw up the AC balance. Maybe bypassing from the wiper to each cathode would make that work but I’m probably the worst guy in the whole world at figuring stuff like that out.
Marty
Can I balance a diff stage like this?Hide this!Advertise here!
Help with diff Amp current balance BunyipElectronics Solid State 16 11th July 2010 03:46 PM
Input xfmr, diff stage, CCS questions zigzagflux Tubes / Valves 14 13th November 2008 11:31 AM
Output stage/preamp with gain: X-Bosoz with diff.-pair? Onvinyl Pass Labs 1 19th July 2004 08:29 AM
Converintg analog stage to balanced on dual diff dacs? check pic. kasra Digital Source 14 31st August 2002 10:11 PM
balanced diff. input stage Altaic Solid State 15 21st July 2002 10:07 PM
