difference between SE and PP transformer difference between SE and PP transformer - diyAudio
Old 27th April 2011, 04:18 PM   #1
hpupo is offline hpupo
Default difference between SE and PP transformer
I always read that the output transfomer for SE is different than for PP. What exactly is the difference? I know one is center tapped on the primary, and of course the pri/sec ratio is different, but besides that is there any other difference? What if i use a PP transformer connected as SE and adjust the load line for the different impedance ratio? would that work well?
Old 27th April 2011, 04:41 PM   #2
quikie22 is offline quikie22  Malaysia
nope.
In simple terms, SE has a gap to prevent/reduce saturation due to the idle current. P-P trans have idle current flowing in opposite directions which therefore cancels the magnetising effect so no saturation due to idle current, so no need for a gap. For low power/current applications, you may be able to get away with using a P-P trans but it would not be ideal.
Old 27th April 2011, 04:42 PM   #3
Got it....
Thanks a lot....
difference between SE and PP transformerHide this!Advertise here!
Restack transformer from PP to SE Mush Tubes / Valves 17 3rd January 2008 04:16 PM
PP transformer for SE?? Help! ThSpeakerDude88 Tubes / Valves 8 7th March 2007 02:28 AM
PP transformer for SE use Brian Donaldson Tubes / Valves 45 11th January 2006 08:16 PM
Copyright ©1999-2017 diyAudio
