diyAudio Sponsor
Old 27th April 2011, 03:40 PM   #1
sbelyo is offline sbelyo  United States
Default I put a bad ouput tube in my amp, did I hurt it?
I did a dumb thing...
I got a 6AS7 off of ebay, tested it and it only posted like 10 on a scale of 0-120. I wanted to see if I could hear anything out of it anyway so I put it in my Van Waarde design headphone amp flicked the power switch and plugged in my good headphones like an idiot.
I got a load hum out of the left channel and nothing out of the right.
I unplugged the headphone and checked the output with a meter just to make sure that I didn't send a stupid amount of DC to the phones, nope just 20 mV I think
It was at that time that I noticed some noise coming from the choke in the PSU. One side of it was hot to the touch and the other side was cold. I cut the power and pulled the tube.
I put the good tube back in and everything sounds normal but I only listened for 10 minutes so I don't think it had much time to warm up yet.
Do you guys think I hurt anything?
Old 27th April 2011, 04:09 PM   #2
Cassiel is online now Cassiel  Greenland
Cassiel's Avatar
Most likely just a little stress, nothing to worry about.
Old 27th April 2011, 04:28 PM   #3
That's what I was hoping. I didn't see any smoke or smell anything odd with my nose to the choke.
I'm always warning other's not to do stupid stuff like this, but I forget to listen to myself
Old 27th April 2011, 07:08 PM   #4
Here's something I've always wanted to know - how do you know when a choke is faulty? I hear of chokes becoming 'oversaturated', what happens then?
Old 27th April 2011, 07:18 PM   #5
boywonder's Avatar
If none of the tube elements were shorted and it just tested weak, that shouldn't cause any harm.
Old 27th April 2011, 07:27 PM   #6
good, there were no shorts
Old 27th April 2011, 07:32 PM   #7
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
depends on the fault!
If the choke overheats or the back EMF is very high you can get shorted turns this means your power supply will become noisy due to lower henrys. (Hum). If you get a short to Gnd then the B+ will either blow a fuse or if no fuse then rectifier or HT winding on power Tx will fail.
M. Gregg
What is the sound of one hand clapping?
Old 27th April 2011, 08:38 PM   #8
@M Gregg Thanks, that helps!
Old 27th April 2011, 08:44 PM   #9
If a saturated choke sits around for a long time the magnetic field will diminish. It also drops a bit just about every time you power it up. So if you don't notice any hum, you got an almost free lesson.
Now you can place the same tube back on eBay and honestly say you tried it and did not like it!
Old 27th April 2011, 08:45 PM   #10
the amp was dead silent before and still dead silent after, so I don't think I shorted any turns
Favorite ouput tube (SE only) rvrazvan Tubes / Valves 61 25th July 2011 02:03 PM
About a I/V tube ouput for a Nos TDA1541A dac gaetan8888 Digital Line Level 1 10th July 2009 07:21 AM
Curious how to put a volume pedal between tube guitar amp head and speakers of same. nova62400 Instruments and Amps 11 30th May 2006 09:03 PM
is there a good or bad way to put sub on wooden floor busterno1 Subwoofers 2 6th June 2004 04:45 PM
Not connecting grids/anode can hurt tube? Redemption Tubes / Valves 6 14th January 2004 11:20 AM
Page generated in 0.10314 seconds (76.80% PHP - 23.20% MySQL) with 10 queries
