diyAudio Sponsor
Old 27th April 2011, 05:18 AM   #1
Default Stereo amplifyer project
Hello
I would like to build this tube amp circuit here Five Tube Stereo Amplifier and I was wondering if anyone knew where I could find some parts for it. I have found mostly everything I need from Surplus Sales of Nebraska but I can not for the life of me find a transformer for it. I'm still pretty new to tube radios but I have replaced a capacitor in one of my radios and plan on replacing another one very soon. I hope to use this circuit to hook up to the audio output from a DVD player and then run it to some Drive-in speakers. That way I can use a projector to project movies and use the drive-in speakers for the sound.
Old 27th April 2011, 06:44 AM   #2
SY's Avatar
Try Antique Electronics Supply (Antique Electronic Supply).
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 27th April 2011, 08:27 AM   #3
mastodon's Avatar
Try Edcor.
Old 27th April 2011, 10:57 AM   #4
For the article's concern about correcting previous schematic errors, here's another: You must also install a capacitor of about .005 mfd between the wiper of each level control and the grid (pin #2) of the respective 6SQ7 input tube. Then, you must also place a resistor of about 10 megohms from each grid terminal and ground. Without these components, there is no bias applied to these tubes, and the sound will be very distorted. These components allow a "contact" bias to be developed, which is very commonly used with these types of tubes and designs.
Dave
Old 27th April 2011, 12:26 PM   #5
Tinkerer
Dave
I agree to that. Better yet, give the input tubes normal cathode bias, because this method is very unstable and changes the operating point when the tube ages. (a resistor parralleled to a capacitor connected between earh and cathode). Would you like me to calculate the resistor and capacitor for you?
Fries with that?
Old 27th April 2011, 12:29 PM   #6
Default First Tube Amp
The circuit you show is a good one but go here for a better "first amp"
Boozhound Laboratories
parts can be found at..
EDCOR Electronics Corporation
Good luck with your project.
Novice stereo subs project with stereo amp. PJeff Subwoofers 70 28th August 2011 06:48 PM
Help with stereo to mono for project g(f(e)) Tubes / Valves 24 24th February 2011 08:39 PM
300B stereo amp project help bartasas Tubes / Valves 2 27th March 2009 03:27 AM
stereo hifi project with fm reciever gideon Chip Amps 2 24th October 2005 06:38 PM
Completed stereo amp project Solid Snake Solid State 3 26th January 2004 05:20 AM
Page generated in 0.08321 seconds (77.72% PHP - 22.28% MySQL) with 10 queries
