diyAudio Sponsor
Old 26th April 2011, 12:20 AM   #1
martyh is offline martyh  United States
Default How close is too close when designing an amp
I’m working on a two stage amp using ECC99s and Sovtek 6B4Gs and trying to fit it to existing power and output transformers. I’m working with published curves and trying to balance supply voltage and operating points.
As it is set right now both stages will run into positive grid voltage before they cut off. Assuming that the curves I am using are accurate it would take 2.75Vrms input to swing the output grids to 0 volts and 4.25Vrms to swing first stage to 0. That gets me enough of a required supply voltage difference between the stages to allow for about 220 Ohms R in a PS filter to isolate the stages.
I don’t have the experience to make judgment call and this is way past my “oh no problem” point. I can’t figure out what would happen if either of the stages needed power on the grid but to be conservative I am assuming that the driver and preamp cannot supply any real current. (I have verified that the driver idle current will handle the input capacitance of the output)
So, since I am working from published curves, am I running things too close to the edge or is this close enough to try building?
Old 26th April 2011, 05:15 AM   #2
kevinkr's Avatar
Have absolutely no idea what you are talking about.. Please post a schematic of your proposed topology and some hard numbers regarding your operating points, and we'll go from there.
www.kta-hifi.net
Old 26th April 2011, 09:35 AM   #3
Sorry I wasn’t clear. 2.75 Vrms at the input gets full class A output from the 2nd stage 4.25 Vrms at the input will swing the input grid to 0 volts which I am taking as the limit. Is the 1.5 volt difference between getting full output and swinging the first stage grid positive enough headroom?
Old 26th April 2011, 11:30 AM   #4
DF96 is offline DF96  England
Better to take -1V as the limit, unless your signal source has low impedance or you don't worry about distortion. Most valves are already taking some electronic grid current between -1V and 0V, although it shoots up as you approach 0V.
Old 26th April 2011, 04:17 PM   #5
tomchr is offline tomchr  United States
tomchr's Avatar
I'm still a bit confused. Here's how I read your statement:
At 2.75 Vrms in, the output stage delivers full output power (which I take to mean the onset of clipping).
At 4.25 Vrms in, the input stage is at the limit of positive grid current (but the output stage is deep into clipping by then).
So your output stage clips way before your input stage. That sounds pretty solid to me. 1.5 Vrms is huge headroom. I don't see any serious degradation in measured THD until the peak input voltage is within 250 mV of the cathode voltage. But that depends on the tubes used and such. But 1.5 Vrms - don't worry about it.
I take the current source you've drawn in the cathode of the input tube should be a voltage source. Otherwise the circuit won't work...
~Tom
Old 26th April 2011, 05:31 PM   #6
~Tom
Hi Tom,
Yes you have it right, thanks for the reply
Marty
CD player Drawer open close open close open close qguy Digital Source 7 23rd November 2006 08:58 PM
Close to the Edge PeteMcK Multi-Way 15 13th July 2005 10:54 PM
how close r watt ratins on a AUDIOBAHN A2300HCT amp n has ne1 used it.. and a jbl gto the bass master Car Audio 7 22nd July 2004 12:18 AM
How close is close? Regis Multi-Way 1 13th February 2004 05:01 AM
how to close a thread Workhorse Forum Problems 3 20th January 2004 07:27 AM
Page generated in 0.09134 seconds (76.48% PHP - 23.52% MySQL) with 11 queries
