diyAudio Sponsor
Old 25th April 2011, 08:51 PM   #1
Default Fatman I tube Problem
I have a problem with a Fatman I Tube. I is only working on one Channel, and has heavy distortion. When i use the headphone socket, both channels work but again with heavy distortion. where should i start to narrow the problem down. thanks for your help Keith
Old 26th April 2011, 05:58 AM   #2
Is this small hybrid amp? Try to replace vacuum tube first.
Fatman? peterbrorsson Full Range 6 22nd September 2007 08:57 PM
Paia Fatman Pot replacements arjun Instruments and Amps 4 20th March 2005 10:23 PM
Tube compressor problem! coony Tubes / Valves 7 1st February 2005 08:08 AM
Page generated in 0.06517 seconds (64.88% PHP - 35.12% MySQL) with 10 queries
