Casanova
Looks suspiciously like your building a clone of Robert Ang's Audio Note M7 clone/variation.
neccesary to use 200mA chokes
A much higher current choke will likely have substantially lower series resistance and therefore a lower Zout. That's probably what they were after.
why 25 x 470uF caps and not just 1 x 10000uF ?
He's obviously aiming for low ESL/ESR, though for a regulated non DHT filament, I can't see a reason for it.
I'd use schottky's in the filament bridge and adjust the values of the last two caps in the B+ to ensure it's stable.
Boutique components
I'll probably be shouted at for saying this, but that drawing looks like a collection of very expensive components with very little evidence of any understanding of circuit design.
The 6072 is a low-noise valve expressly designed for audio that used to be used in AKG microphones. DC heaters help reduce hum, as does a well filtered HT supply. Regulated DC on the heaters stabilises cathode temperature, which is a good thing (and cheap to do), without needing lots of boutique components. Since the output impedance of the HT supply is primarily that of the final capacitor, the low DC resistance of over-sized chokes will have very little effect.
I'd suggest that you use the 6072 section, but make your own power supply arrangements with whatever you have handy. As Brett suggested, it is well worth using Schottky diodes for the LT. Also use a separate transformer for the LT from the HT to prevent HT rectifier spikes appearing on the LT. After rectifying and smoothing the LT, use a regulator of your choice to set 6.3V on the valve pins. Use a low-leakage (ceramic or PTFE) valve base to minimise noise.
To make the project more interesting, you might like to consider a valve HT regulator in place of lots of expensive iron.
The heater smoothing circuit looks like over-kill to me.
If you take Bretts suggestion of a Schottky bridge, and increase the 1 ohm resistor, you'll be able to reduce the smoothing cap requirements. Have a play with PSU Designer to see what's going on.
As for the multiple parallel caps? Sometimes it's just to get it into a low profile box.
6072 is a very good sounding valve. I like it mostly in phono stages but no doubt it also sounds good at line level. BTW WIM (MR Valve) in JHB has lots of new old stock 6072s. The heater PSU has a strong effect on the final sound even with IDHTs. However the solution shown is probably not optimal - just a single Elna Cerafine 10,000uF before the cap multiplier should do the trick with little capacitance close to the the valve. A larger improvement than the crazy multi-cap mish-mash can be had with a high current choke in the heater supply.
cheers
peter
cheers
peter
Thanx for all the good news.
After looking around locally (whole of South Africa) , I was just about to look for another circuit. All those fancy caps will cost a small fortune to import. I noticed that the 6072A can be replaced by the 12AY7. Is this wise or must I rather get the 6072A. I got 4 x 12AY7's at moment, but of mixed brands (RCA, GE, Heintz & Kaufman) - so I must buy new ones anyway. What should the PSU trafo. rating be? 100VA good enough?
Re: Casanova
Quite right.
http://www.audio-genesis.com/casanova.html
Brett said:Looks suspiciously like your building a clone of Robert Ang's Audio Note M7 clone/variation.
Quite right.
Re: Re: Casanova
I recognised the schematic.
Robert's using a different pre now, a choke loaded or WOT 76 iirc.
contaxchen said:Hallo,
I've a problem. After cutting the phono section off, what are we gonna handle the rest? Can I just replace the whole phono section by a little proper-valued resistor to balance the whole circuit?
What phono section? The circuit you posted is a line amp only.
Re: Casanova
...or a 12AY7 version of the Foreplay with DC heaters and a boutique pi-filtered PSU.
The original M7 has a phono section with it.
Please look at the link.
I'm asking the general principle to reduce the phono section. Hope that's not too stupid.
Thanks,
cchen
PS. This is not my thread.
http://www.drtube.com/audioamp.htm
Thanks,
cchen
If you don't need it than just don't build it, just build the linestage.
BillyF said:It is in my wish list to DIY and even wrote to audio genesis for the same question but I didn't received any reply.
Billy,
Robert (Audio-Genesis) is very busy with other aspects of his life, and likely doesn't have the time to reply at the moment. May I suggest you ask any questions here.
PSU size for pre-amp
I got hold of a 14H 150mA choke and a trafo of unknown VA. When connected as in attached circuit, I get 294V DC without any load, 260V @34mA and 252V @ 42mA.
1) For the circuit in my 2nd posting, 200V is required: Will it be O.K. if using the 12AY7, which I got 4 of, with a supply in the range of 250 to 290V?
2) How much current will this circuit normally draw @ 200V, with both channels?
Thanx for any help.
Thanx for any help.
- Tubes / Valves
- Preamp PSU questions
