A quick question about NFB
Old 22nd April 2011, 11:40 PM   #1
HFGuy is offline HFGuy  Canada
Default A quick question about NFB
I've built the following amp
I have yet to actually apply the NFB, but I am ready to do now. I just wanna be sure if the NFB signal should be in-phase or inverted from the input signal ?
Old 22nd April 2011, 11:59 PM   #2
jjman is offline jjman  United States
Depends upon the tap and the insertion points, not on the input. Although if it's to be inserted into the 1st stage it needs to be out of phase with the signal that's at that point.
Old 23rd April 2011, 12:02 AM   #3
On Hiatus
SY's Avatar
Yes, you want it to be in phase with the signal at the grid. The input tube looks at the difference between cathode and grid voltages, so if the polarity is opposite of input signal, the feedback will be positive.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 23rd April 2011, 12:10 AM   #4
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
It should be in-phase. The signal input is the non-inverting input, and the gNFB is connected to the inverting input. Just like an op-amp. Unlike op-amps, or OTLs, polarity isn't so apparent due to the OPT.
Connect a 8R, high wattage power resistor to the output, o-scope the output, and see what happens. If Mr. Murphy wired the OPT for positive feedback, you will see a large, somewhat square wave, across the output load resistor at ~25Hz (more or less depending on the OPT) as the whole amp makes like a Royer oscillator. (Which is why you want to use a resistor and not the speeks as the test load.)
If that happens, then reverse the plate and screen connections at the OPT primary to reverse the polarity.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 23rd April 2011, 12:33 AM   #5
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Or, more easily done, swap the phase splitter outputs.
Old 23rd April 2011, 12:55 AM   #6
Thank you all for the response ... I kinda figured it had to be in-phase. Strange enough is that the schematic on the Plitron is wrong. I will have to swap the phase somewhere. BTW the long drawn out story of trouble shooting this amp is on this thread
http://www.diyaudio.com/forums/tubes...out-ideas.html
Old 23rd April 2011, 01:24 PM   #7
roline is offline roline  United States
roline's Avatar
Feedback is easy to check, if properly hooked up output volume is reduced and well behaved, if hooked up wrong, increased volume and it acts like a 2-3 yr old with a tantrum.
I bring up all of my amps without to start, get all of the DC biasing levels correct and then hookup GNFB and adjust the amount for best sound performance.
SO many tubes, SO little time!!!
Old 23rd April 2011, 02:44 PM   #8
Globulator is offline Globulator  United Kingdom
Globulator's Avatar
If you have a dual input scope, the feedback signal should in the opposite phase to where you intend to solder it to, so it subtracts from that signal.
Also after reading posts by Kuei Yang Wang I became convinced that leaving the output transformer out of the feedback might be a much better idea - and after testing this on my GU50 SEP amp I have to say I agree with him.
So my feedback now runs from the output tube's anode to the (non bypassed) cathode on the driver stage - giving a considerable better sound than an overall loop. I.e. now both the input stage and the transformer are feedback free, but the driver/output tube pair are in a tight loop to drive a low impedance into the transformer.
YMMV.
Old 23rd April 2011, 04:38 PM   #9
Thanks to all of your help I wired up the NFB after swapping the outputs of the phase splitter. I will post some snap shots of the square waves later tonight. The one big advantage of applying the NFB was the huge loss in gain. The amp now saturates with a 1.6V input instead of a 0.6V input so I can use it much easier with preamps
Old 23rd April 2011, 09:52 PM   #10
I posted the results on my other thread.
A quick question about NFBHide this!Advertise here!
Better Audio with or without NFB (Negative Feedback) - for me the wrong Question tiefbassuebertr Solid State 61 31st December 2012 05:36 PM
NFB question GAK Tubes / Valves 52 6th June 2011 02:05 AM
6bl8 el84 nfb question joshuahhhhhhh Tubes / Valves 2 17th December 2007 05:18 AM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
Qm value for zero NFB amps question andyjevans Multi-Way 0 12th February 2004 01:52 PM
