| diyAudio Sponsor | ||
Hi all,
I am not a newbie DIYer (may be as you already know...). And have made a lot of IC, SS amplifiers, tube buffers-preamps for my ear taste until now. Presently I have a pair of Tang Band W5-1611SA full range speaker with 17lt bass reflex box tuned @52Hz.. And a Pass F5 amplifier feeds them. I must say that I found them very satisfactory at the meaning of analytical/clinical sounding. However I think my soul needs more musical things to listen.. Like a SE tube amplifier.. So, at this time I will need your advices about the choice.. I have a pair of NOS EL34, some 6N6P and some 12AU7s in my drawer.. In fact what I have is not important. But I see a lot of SE applications with EL34 tubes in the internet. I think just a triode input stage (with SRPP may be) and an EL34 works fine for my needs. However I cannot be sure to select one of these projects.. May you please advice a SE project for me? And what about the output transformers? Does a HAMMOND 1628SEA suitable for this amp or a cheaper one like; 5K SE AUDIO OUTPUT TRANSFORMER FOR ,KT-88, EL-34 | eBay Thanks a lot in advance for anykind of helps..
Best regards, Ozgur |
#2 |
#3 |
This sounds pretty good. RH 807 - Tube Audio ...... RH DESIGN
You could use the EL34 instead of the 807. Driver stage with 12AT7 can be augmented by a cathode follower constructed from 6N6P. |
#4 |
Thanks a lot.. But is it just 1.5W ???
![]() I afraid it wont be enough for me!
#5 |
Please read through fully. 1.5W was referencing the single-ended triode connected EL84 amp he had listened to. :-)
This one should provide much more than that. Even the RH84 which is based on a similar design but with EL84 puts out about 4W of power. EL34 should easily double that. If you use a cathode follower, you can probably drive it into A2 territory too... with even higher power. |
#6 |
hmmm.. I gues I must make some mods on the circuit! However I dont think so.. May you explain a bit more please?
#7 |
here is one schematic. I have made a circuit similar to this using gu-50 and 6N6P and 12AT7. Look at artosalo's design. This is what I meant. You could replace the GU-50 with any output tube of choice but of course with different transformers and bias schemes.
GU-50 in Single-Ended Triode Configuration - What bias points? |
#8 |
Sure.. But this is my first tube power amp. So I dont think I can do that.
Thanks a lot.
#9 |
:-) The RH84 was my first tube power amp project. The GU-50 my second one. :-)
Like you, i had already completed several SS amps (chipamps, Pass F5, Pass BOZ, various MOSFET/BJT amps) before my foray into tubes. You will be surprised how similar tube circuits are and are in fact simpler to grasp. There a lots of circuits floating out there in cyberspace. Have a look at all of them and decide. Took me 3 months of research and another 3 to get the parts for my first EL84 amp. You will be surprised how loud 4W or 8W can get you with tube equipment. I guess the 2nd harmonic distortion tends to "fatten" the sound and make it louder than the SS amps. The 8W GU-50 amp seems to beat the F5 easily. I think many of those on this forum have the same experience. |
#10 |
Thanks for this suggestion. For the power supply my ground comes from the centre tap and the HT is referenced to that... so how does one get a negative voltage?
| RH84 SE, pentode driver... advice please | bigjppop | Tubes / Valves | 146 | 17th October 2011 03:49 AM |
| Needed - Advice on tubelab Simple SE build | Salsero | Tubes / Valves | 2 | 30th December 2009 06:51 PM |
| Looking for advice/tips regarding simple SE amplifer | Arnulf | Tubes / Valves | 9 | 19th March 2009 10:14 PM |
| SE setup need amp advice | ttruman | Multi-Way | 10 | 12th April 2008 05:14 PM |
| Advice on SE DHT for Lowther Fidelio DX2 | Rudolfs1972 | Tubes / Valves | 5 | 31st July 2007 10:18 PM |
| Page generated in 0.09182 seconds (86.78% PHP - 13.22% MySQL) with 10 queries |
