Info wanted on OPT....
Old 19th April 2011, 04:29 PM   #1
nickds1 is offline nickds1  England
nickds1's Avatar
Default Info wanted on OPT....
I've just been given the OPT from a Velleman K8011 monoblock amp - its a toroidal BEAST (90W). Its marked "ZD 043".
The Velleman manual is at http://www.velleman.eu/downloads/0/manual_k8011.pdf
Does anyone have the spec for this xfrmr?
Cheers
Nicko
"The whole plan hinged upon the natural curiosity of potatoes" - S. Lem
Old 19th April 2011, 04:37 PM   #2
hidnplayr is offline hidnplayr  Belgium
hidnplayr's Avatar
It should be a type ZD043
Primary: 2 x 1K, taps at 1/3
Secondary: 4 and 8 ohms
90W max
bandwidth: 2Hz to 125kHz (-3dB/1W) (probably with feedback applied)
Real tubes have top-caps
Old 30th April 2013, 08:59 PM   #3
M Gregg is offline M Gregg  England
Has anyone used these transformers for other tubes...
It seems a strange primary impedance..
M. Gregg
Old 30th April 2013, 09:39 PM   #4
dovla is offline dovla
Default PPP?
M. Gregg
Sounds like something meant for 4 or more tubes in PPP (i.e. trioded EL34s) or 6c33
Old 1st May 2013, 12:59 AM   #5
gingertube is offline gingertube  Australia
By 2 x 1K they actually mean 2K anode to anode (Raa) even though to be technically correct 2 x 1K would actually mean 4K Raa. It is one of those annoying little snippits of information posted to the web which is quite missleading.
So 2K Raa with what seems like 30% Ultralinear taps is what it really is. It will suit a quad of the usual suspects ie. EL34, 6L6, KT77, KT66 in parallel push pull. You could also use 4 off 6550 or KT88 at slightly lower voltage to keep the power down to the 90 Watt level.
6 off 6L6 is one more option at lower B+
At lower B+ it would also suit 8 off 6V6 or EL84 or 4 off sweep tubes like 6CM5, 6DQ6 etc.
Heap of options.
Ian
Info wanted on OPT....Hide this!Advertise here!
BA6353S info wanted anatech Digital Source 4 11th December 2011 03:12 PM
Info on SM042 wanted JonHarrison Solid State 4 30th January 2007 02:56 PM
Enclosure info wanted mikee55 Parts 2 28th January 2007 12:44 AM
B&W DM7 info wanted Jerry T. Multi-Way 2 26th January 2005 05:59 PM
info wanted about a output transformer goudfazant Tubes / Valves 9 22nd December 2004 06:16 PM
Copyright ©1999-2017 diyAudio
