My new filiment PS for Push Pull GM70
Old 18th April 2011, 04:22 AM   #1
djn is offline djn  United States
djn's Avatar
Default My new filiment PS for Push Pull GM70
A friend just gave this to me. 2 channles of 24volt, 6 amp DC power. I think it would be a great filiment PS for a push pull GM70 amp. The GM70 needs 20v, 3a. It weights 38lbs!!! Talk about a boat anchor....and that is just a fraction of the whole amp. I think it will do nicely.
Old 18th April 2011, 11:27 AM   #2
Bandersnatch is offline Bandersnatch  United States
hey-Hey!!!,
For PP Dh amps I have not found DC heating required...at least not with 10V 813's. 5V tubes absolutely not, and 2.5V tubes...not even close.
cheers,
Douglas
the Tnuctipun will return
Old 19th April 2011, 12:04 AM   #3
djn's Avatar
Hey D, sorry we missed you yesterday. I know this might be over kill and I still have three amp projects on the bench, but what the hey! George asked me if I wanted it, so what the heck.
Old 19th April 2011, 12:15 PM   #4
That's mighty strange, I've never known you to go in for 'overkill'...LOL
Douglas
Old 19th April 2011, 12:52 PM   #5
djn's Avatar
Bad habits die hard
Old 19th April 2011, 05:41 PM   #6
kevinkr's Avatar
Originally Posted by Bandersnatch View Post
hey-Hey!!!,
cheers,
Douglas
These are 20V tubes and DC is advisable if you need really low hum even in PP. I found with 300B PP amps driving very efficient speakers (>100dB) that DC was also advisable, although not strictly required if you can live with a mVrms or so of hum/buzz on the output..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 19th April 2011, 07:56 PM   #7
djn's Avatar
I agree Kevin. I generally run compression drivers that are 115db eff. and any hum is audable. Besides that, it is a simple one piece unit that just needs wire hooked up. no muss, no fuss.
Old 19th April 2011, 10:05 PM   #8
radiostar is offline radiostar  Yugoslavia
Good starting point and good luck with new project djn!!!
GM70 PP would be a beast ...
tubes.rs
Old 19th April 2011, 10:21 PM   #9
djn's Avatar
Thanks Radio. I have three other amps on the bench but getting ready to move, so I dont think this one will be up and running any time soon, but that only means I have time to collect parts. Should do well with 800v B+. I don't know how to figure what the WPC will be but I'm sure it will be more than my GM70 SET.
Old 20th April 2011, 12:07 PM   #10
I have 813's on AC with horn-loaded EV DL10x and don't hear anything unless I stick my shoulders into the horn. I can live with that. Individual coils for each tube and their own hum pot. Variac on the primary to dial in exactly 10V, though it seems to be quite happy with 10.2-10.5V on them.
cheers,
Douglas
My new filiment PS for Push Pull GM70Hide this!Advertise here!
"Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name? tiefbassuebertr Solid State 70 15th August 2012 09:08 PM
Push-Pull vs Push-Pull-Parallel rsumperl Tubes / Valves 8 10th July 2012 06:34 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
Push Pull bellx Solid State 3 25th January 2004 11:59 AM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 01:23 AM
Copyright ©1999-2017 diyAudio
