Re-bias when changing from Triode to Pentode - diyAudio
Old 16th April 2011, 02:01 PM   #1
Send a message via MSN to ronenash
Default Re-bias when changing from Triode to Pentode
I was wondering if I need to re-bias my amp every time I change from Triod operation to Pentode operation. Anyone has an idea?
ronenash
Old 16th April 2011, 02:18 PM   #2
TG is offline TG  Ukraine
Send a message via ICQ to TG
It depends roughly on the voltage at the g2 in pentode mode. If it's the same as in triode mode, than you don't need to re-bias the output tube.
If you can share the schematics, it would be easier to figure out.
Old 17th April 2011, 02:18 AM   #3
Attached is the schematic. There is a switch I put in that either connects the screen to the Anode through a 150 ohm resisitor for triod operation or connects it to the output tranny as currently shown in the schematic.
I appreciate your help TG.
ronenash
Old 17th April 2011, 09:03 AM   #4
Ah, so you want it to be triode/ultralinear rather than triode/pentode.
OK, here's what we have (at idle):
1. In the triode mode screens are ~1..2V below the plates (I presume that output tubes are something KT88/EL34-ish, so screen current is unlikely higher than 5-10 mA).
2. In the UL mode screen voltage depends on R38/R39 values. The 'tranny' ends of these resistors will be a couple of volts above the plate, but some voltage will be dropped across them due to screen current.
In any case, screen voltage will not change much with mode switching, so I'd say you may not bother to re-bias the tubes. Or, if you want idle current to be exactly the same, you can adjust R38/R39 values (200-220 Ohm is a good start) and make it so.
Old 17th April 2011, 09:10 AM   #5
Thank you TG. This is most helpfull.
ronenash
Dynamic Bias - Active Bias - Automatic/Self biased - Overview wanted tiefbassuebertr Pass Labs 16 29th July 2012 04:03 PM
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Bias problem- 1 Socket shows extremely low bias! otokomae Tubes / Valves 12 31st December 2008 10:01 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
Copyright 1999-2017 diyAudio
