K & K Audio Two Terminal Constant Current Source
Old 15th April 2011, 03:07 AM   #1
rsumperl is offline rsumperl  United States
rsumperl's Avatar
Default K & K Audio Two Terminal Constant Current Source
Greetings everyone,
Just wanted to ask if anyone has used the K & K Audio Two Terminal Constant Current Source and what their experience has been like.
Thanks,
Ray
Old 15th April 2011, 10:37 AM   #2
mastodon is offline mastodon  Netherlands
mastodon's Avatar
No experience, but those kits are literally nothing more than a depletion mode mosfet, one or two resistors and a trimpot. I don't really see the added value of purchasing this as a kit instead of buying the components and wiring them in a point-to-point fashion.
Old 15th April 2011, 10:42 AM   #3
Raj1 is offline Raj1  United Kingdom
I suppose anyone that's asking the OP question probably needs a schematic to build something of similar ilk...
Old 15th April 2011, 10:47 AM   #4
mastodon's Avatar
Click the image to open in full size.Fair enough
Old 15th April 2011, 11:05 AM   #5
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Which one?
But never mind about the non-cascaded version. Get a cascaded version. (If you plan on using it as a plate load OR in the tail of a LTP) The non-cascaded version would do fine for instance in the output section of say a Baby Huey PP EL84.
And as mastodon says you could build those yourself.
The IXYS IXTP01N100D is reputed to sound better than the Supertex DN2540N5 and that is why K and K now use them. (Actually they use both in the cascaded but one is strategically placed where it has more effect)
Unfortunately us Europeans cannot buy IXYS IXTP01N100D.
If you can see the speaker cone move...it's not hifi.
Old 15th April 2011, 12:06 PM   #6
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
Only thing I don't care for with the design is they thermally bond the two FETs together on the heat sink. By keeping the lower FET isolated and in free air (it doesn't dissipate much anyway) you reduce long term thermal drift. The upper FETs current is dictated by the lower.
Old 15th April 2011, 01:21 PM   #7
Doz is offline Doz  United Kingdom
Doz's Avatar
Ironically , I used to buy IXYS IGBT's from the Netherlands
Digikey will ship you one...
"To err is human.. to make a real balls-up requires a computer"
Old 15th April 2011, 01:28 PM   #8
mastodon's Avatar
So will Mouser.
edit: Oops, they won't.
Old 15th April 2011, 01:46 PM   #9
On Hiatus
SY's Avatar
Two DN2540, three resistors, you have a current source as close to perfect as one could even need in audio. $3 plus a square inch of perf board. Heat sink on the upper FET. You're done.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 15th April 2011, 03:15 PM   #10
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
yeah, we 'noobs' really should learn to do this
but you know, even simple diodes can cause headaches to some us
I wouldn't mind more input on this subject
K & K Audio Two Terminal Constant Current SourceHide this!Advertise here!
constant current source hacknet Solid State 19 13th March 2006 03:46 PM
Constant current source for Clone audioandy Chip Amps 2 27th January 2004 12:55 PM
Constant current source -3000V olvrkrg Solid State 25 10th January 2004 07:19 PM
constant current source question Randy Knutson Parts 0 31st March 2003 02:42 AM
Copyright ©1999-2017 diyAudio
