diyAudio Sponsor
Old 12th April 2011, 08:10 PM   #1
gaffer is offline gaffer  United Kingdom
gaffer's Avatar
Default ZKIT2 Zen Triode mono SET amplifier kit
I am looking for a list of components for these amp boards. I would like to buy these components in the UK. I have already made the PC-Boards. I just need a transformer and a suppler for these components. High Fidelity Engineering (Decware) are not interested in people that have second hand units.
I now have two of these valve amps boards, both have circuit board problems, which I would like to fix. I would like a list of components that are on these circuit board, plus any info I can get. Can any one help me.
Old 13th April 2011, 12:06 AM   #2
rvrazvan's Avatar
I can provide you de list and more. I've build a stereo amp based on Zen Triode using russian equivalent tubes.
I haven't used a prinded board. Point to point it's easy for this amp.
I still have a few issues with it but is can be solved using an eq. The cause it's the OPT's i guess as i'm using salvaged transformers(poor quality).
The amp sound's sweet. And it's not just my opinion. I will come back tomorrow with the part list and the rest.
Good luck.
Bdw. You can find the schematic for the stereo amps on decware.com. It's a good start
Old 14th April 2011, 03:35 PM   #3
gaffer's Avatar
That would be great, if you sent me the parts list
Old 14th April 2011, 06:52 PM   #4
rvrazvan's Avatar
http://www.decware.com/newsite/SE84CDIYMONO.pdf
i'm short on time
have you seen this?
Old 14th April 2011, 07:17 PM   #5
gaffer's Avatar
It still would be great if you sent me the parts list
FS: Dual mono LM3886 Gainclone Amplifier kit sachi Swap Meet 1 16th May 2010 01:28 AM
Decware SE84CS Zen triode amplifier for sale. jim_vt Swap Meet 9 4th September 2005 11:57 PM
I have maked a Zen Headphone Amplifier Kit digi01 Headphone Systems 14 10th March 2003 02:12 AM
Page generated in 0.08696 seconds (73.07% PHP - 26.93% MySQL) with 11 queries
