diyAudio Sponsor
Old 12th April 2011, 06:09 PM   #1
manp111 is offline manp111  United States
Default Tango 11146 Output Transformers ?
Does anyone have any information about the Tango 11146 Output Transformer?
Old 12th April 2011, 06:56 PM   #2
WALTER BURKHARD's Avatar
the Tango 11146 Transformer is a special order Model.
Mostly there are input tarnsformers
regards
Walter
Old 12th April 2011, 07:23 PM   #3
Thank you Walter.
Is there a way to figure out the primary and secondary impedance?
Perhaps by measuring the resistance between the pins and some how convert the measurements?
NOS TANGO U-808 OUTPUT TRANSFORMERS FOR SALE Bonanza Swap Meet 2 17th October 2010 05:29 PM
Tango U808 and Audio Note Output Transformers for Single Ended Projects hifidaddy Swap Meet 6 14th April 2010 11:40 AM
Insides of Tango Transformers korneluk Tubes / Valves 6 30th August 2008 01:30 PM
Page generated in 0.07130 seconds (63.55% PHP - 36.45% MySQL) with 11 queries
