Aronov LS9100 - any info ??? - Page 2 - diyAudio
Old 18th February 2013, 05:00 AM   #11
Well they are finally both back together. New set of Output tubes for the blown up unit. Due to the grid leak resistor values (270K) I biased them very conservatively at 60mA idle each tube.
Both 6AN8A had weak triode sections (the concertina phase splitter) so put new RCA 6AN8A in both monoblocks.
Ran them for 2 hours on my system for a final confidence test.
What did I think of them ? Well frankly I far prefer my 10W per Channel 6V6 Baby Huey. Better Imaging, better pace, less low end "covered" veil, better top end extension, well better everything except maximum volume.
Ian
Old 24th February 2015, 12:54 AM   #12
Relocate the ground sos it's not running across the (entire) case and better caps.
It will become heavenly and continue to warm your room on a cold night. pc
Need info on my Onkyo, can't find any info anywhere. gixxierific Digital Source 0 19th April 2009 04:49 PM
Yakov Aronov amps llwhtt Tubes / Valves 0 21st September 2008 08:37 AM
How to get cathode bias info from grid bias info? leadbelly Tubes / Valves 8 14th August 2008 05:40 PM
Got info?! looking 4 info on the BG Neo 10 gp4Jesus Planars & Exotics 1 18th November 2006 04:14 AM
Info sia Parts 0 24th April 2004 02:47 AM
Copyright ©1999-2017 diyAudio
