diyAudio Sponsor
Old 11th April 2011, 12:46 PM   #1
Bill*B is offline Bill*B  United States
Default Positive feedback for amplifier input stage
Best gurus:
I just saw an amplifier schematic where the input stage had about 2 dB of POSITIVE feedback from the driver, within a global NEGATIVE feedback loop of around 20 dB.
The designer made much of this as contributing to a "powerful sound". It appears to me that he simply has 18 dB of negative feedback, but am I missing something?
Regards, Bill.
Old 11th April 2011, 01:22 PM   #2
Yvesm is offline Yvesm  France
Yvesm's Avatar
According the way the positive feedback is applied to an input stage, f.e. at the anode of a triode, it may increase its drive capabilities while reducing distortion.
An ancester of the CCS load also know as bootstraping.
Yves, Worst guru.
Old 11th April 2011, 01:51 PM   #3
Thanks, Yves. It was a 12AX7, so increasing the drive capabilities does make sense. Bill.
Old 11th April 2011, 02:24 PM   #4
revintage's Avatar
Dave Hafler uses it in his amps. For example, check the phonostage of PAS3, where the positive feedback is between the cathodes.
Brgds
Lars
Old 11th April 2011, 04:35 PM   #5
kevinkr's Avatar
Deliberately applied in order to boost the open loop gain - a juggling act that if carried to the extreme results in an oscillator, and also significantly increases distortion IMLE. IIRC in the case of the PAS 3 the increase in open loop gain was something like a few dB. There are number of issues with the design of the PAS 3 phono stage, probably the most critical of which is the extreme loading on the second stage. See: Spice and the art of preamplifier design, Part 1
www.kta-hifi.net
Old 11th April 2011, 08:54 PM   #6
Thanks, guys. Lots of good data, as always. Here's a link to the schematic that got me interested: it loads a little slowly! Regards, Bill.
Old 11th April 2011, 09:08 PM   #7
GordonW is offline GordonW  United States
GordonW's Avatar
IIRC, Stuart Hegeman, then working for Harman-Kardon (or just before he went there?), either pioneered, or was an early adopter of this practice, in the late 1950s. My HK Award A300 has this circuit design... 12AX7 driver, 12AU7 phase splitter, 6V6 PP outputs. I'm about to build an elaborate integrated amp, using the Harman HK250 circuit design (PP 6L6s)... it uses a 6CG7/6SN7 type tube for the input driver and phase splitter, with the positive feedback increasing the open-loop gain... allowing a decent amount of feedback, while still having enough gain for a good preamp stage to be able to drive it, easily...
Gordon.
Speaker Design, Restoration and Repair- since 1985.
Old 12th April 2011, 08:29 AM   #8
The QUAD II also uses positive feedback so it must work, then.
Old 12th April 2011, 10:25 PM   #9
Didn't Dynaco use that trick in their power amps?
mike - www.keepingsundayspecial.org
Needed: single transistor audio amplifier with positive feedback neazoi Solid State 44 29th October 2011 03:47 PM
Neural positive feedback loop investigated tsmith1315 The Lounge 1 24th July 2010 03:50 PM
Positive/Negative Feedback cbj591 Tubes / Valves 9 12th July 2010 07:49 AM
Modulated cascode and positive feedback? Circlomanen Pass Labs 4 13th March 2006 01:14 PM
Positive feedback online issue #16 Original Burnedfingers Tubes / Valves 0 22nd March 2005 11:25 AM
Page generated in 0.08250 seconds (85.95% PHP - 14.05% MySQL) with 10 queries
