diyAudio Sponsor
Old 9th April 2011, 04:53 PM   #1
Default Correct power rating for Chicago OT - opinions
I just acquired an old Chicago BO-12 PP OT and was looking for a good amp to build with it.
The only online catalog I could find lists this unit as a 10W rating suitable for 807s. I think this must be a typo based on tube type and the size of the transformer : 4 X 4.5, X 5.5, 9lbs. 807s could be ran class A triode at 6W but every other operating condition is 15W to 80+W.
http://www.bunkerofdoom.com/xfm/CHICAGO1953/014.jpg
So the question is: If it's not 10W, what is the accurate rating? My first guess would be 40W based on size relative to their other 40W iron. Still, 40W seems kind of a narrow application window for 807s, and I certainly don't want to burn up this transformer.
TDSL Tube data [807]
Does anyone have another Chicago catalog to verify this? Any guesses as to the true rating or opinions as to what power limits I should keep?
Old 9th April 2011, 06:05 PM   #2
HollowState's Avatar
Your information is correct. This is a scan from a 1966 Radio Master.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 9th April 2011, 07:07 PM   #3
Thanks for the scan HollowState. Officially the biggest 10W OT I've ever seen.
Comparing it to the BO-13 - same basic Z taps except BO-12 has the 600r winding. BO-13 is 20W and a smaller case size. Wonder if the 600r winding accounts for that. BO-9 is 15W w/600r tap and still smaller case size but less wire for the primary. Difference must be in the pri current ratings - 100ma for the BO-12 and only 75ma for the 15W BO-9. Looks like it might be good for a nice class A 807 triode strapped amp.
Anyone have another single BO-12 they want to get rid of?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
SE OT power tube suggestions please! mario13 Tubes / Valves 3 9th April 2011 09:55 PM
power calculation...correct? lt cdr data Solid State 3 13th September 2006 11:45 AM
Power rating set Multi-Way 2 15th January 2005 02:48 AM
Opinions sought on Heatsink rating (see photo) Nicwix Pass Labs 6 17th July 2002 10:38 PM
Page generated in 0.09080 seconds (73.56% PHP - 26.44% MySQL) with 11 queries
