diyAudio Sponsor
Old 9th April 2011, 03:07 PM   #1
Default S5 K8-LM mono KIT (total newbie)
Hello,
My name is Danny, been a little active in the speaker forums.
I have BiBs with Fostex 168 sigmas (i love em) and want to build my first tube amp.
I have some experience in electrics, but i'm not counting on it. Started to read about the tubes and safety and the lot.
I've ordered the two monoblocks from S5 without the transformers (too heavy to ship to europe). I got the specs for them. I've been looking for the Hammond trans (read somewhere that they are good replacement-upgrade to stock). Perhaps I didn't done enough reading, but I cant find any that match the specs.
My questions :
- has anyone build this kit?
- what replacement transformers? (i know, i will have to get into the theories)
- if yes, what part number for Hammond? (available in UK)
- what mods to upgrade the bass response? (i read that they lack in this region)
- what mod (description) to discharge the amp after power off? (safety, small children)
I will make a proper chassis for it, that is sure.
Please don't stone me for these questions, I'm just starting with amps
Danny
P.S.: any, I mean really ANY suggestions are highly appreciated.
Old 9th April 2011, 05:17 PM   #2
I haven't built one but...
Is it this one?
Model 8LS Stereo Integrated Tube Amplifier
If so it looks like it uses these for output tubes.
http://scottbecker.net/tube/sheets/093/6/6005.pdf
Just based on the data sheet it looks as though it likes about 10K ohms plate to plate on the output transformer primary.
What specifications did they give you on the transformers? Do you have the schematic yet?
mike - www.keepingsundayspecial.org
Old 9th April 2011, 05:33 PM   #3
Hello mashaffer
thanks to chime in.
its this one :
Untitled
actually two the specs for the trans are:
Output Transformer =
Ratio 35 : 1
Primary Resistance 400 ohms
Secondary Impendence 8 ohms
Power 10 watts
Power Transformer =
120 / 220 VAC in
180VAC @ 0.250ma Secondary #1
6.0 VAC @ 5.5 A Center Tapped Secondary #2
I'm pretty sure that the secondary should be 250mA, not 0.250mA
it uses 5670 triode and 6005 pentode tubes. so you were spot on
The kits re on the way, i'm sure the schematic is somewhere on the net, but it will arrive with the kits.
Danny
Old 12th April 2011, 04:41 PM   #4
What a stupid assumption from me in the previous post
read read read and then post reply
OK, so I wrote to Hammond with the specs I need,
They replied with this:
This amp is a single ended topology (one tube ) . ( I DON'T THINK SO when it says PUSH-PULL)
The recommended primary impedance is 5000 ohms. The suggested output transformer is:
125ESE
125FSE
1628SEA (please see the links below)
Hammond Mfg. - Universal - Single Ended - Tube Output Transformers - (125 Series)
Hammond Mfg. - "Classic" Single Ended Tube Output Transformers - (1627 - 1642 Series)
The power transformer is a difficult cross. Most of our product line uses full wave center tap, High voltage secondary's. This request is for a Full wave bridge.
Our closest match would be 363CX (using 1/2 of the secondary) at 250A .
The secondary transformer would be: (WHTA DO THEY MEAN BY "SECONDARY TRANS"?)
182L6 or
185D12 or
266PA6
Hammond Mfg. - Toroid Power Transformer - (182 Series)
Hammond Mfg. - Power Transformers - Global Use - (185 Series)
Hammond Mfg. - Power Transformer - Dual Primary / Dual Secondary (266 Series)
So this is their reply.
Did anyone actually build the 8W Mono amps yet?
I had a good look on the picture on their page and when you look closely the power transformer for the K-16LS and the K-8LM have same stickers. Does this mean they are totally same?
If yes, could I use a power trans that somebody used in the 16W stereo kit?
Danny
Any help appreciated ( I can serve as a guiney (spell?) pig for these monoblocks for future builds.
Old 12th April 2011, 10:19 PM   #5
For hammond it looks like 1609 or 1609A are the most appropriate for your OPTs although I would like to see more margin in the power handling but they should work fine.
Undoubtedly the kit needs 250mA rather than .250mA as you say.
For power his first suggestion seems to be the best that they can offer. Alternately you could use that PT and redesign your kit to use a full wave (two diode rather than the four diode bridge) and use the entire primary. Doing this would allow it to run quite cool.
Maybe there are some other transformer makers that you could look at. I would be surprised if a 200mA secondary were not enough for the B+ but a detailed look at your schematic would help.
Old 13th April 2011, 06:39 AM   #6
Thanks mashaffer,
still waiting for the kit to arrive, the schematic is inside, as soon as I will have it I will put up a picture.
I think it will be something like half of the K8-LS stereo which is somewhere here on the forum (I will find it, perhaps it helps).
Danny
Old 13th April 2011, 09:05 AM   #7
rvrazvan's Avatar
I bet you can find someone to wind you a transformer in your country for not alot of money. Poland is a great source for the output transformers and tubes. Also ukraine is a good source of russian tubes. they cost next to nothing.
.:: INDEL Sp. z o.o. ::.
they have output transformers and power transformers also. but first you need to wait for the kit so you'll know what you need.
Old 13th April 2011, 09:14 AM   #8
rvrazvan:
thanks for the suggestion, but I'm from Slovakia and I work in Netherlands, many days a week on business trips. I simply don't have the time to go and let some make me a trannie. I need ready made product ))
But many thanks for suggestions.
I bet when I have the kit and will post the schematic it will be much clear...
Danny
Old 15th April 2011, 09:35 PM   #9
OK guys, here is the schematic....
I hope it can help the guru's over here to help me
Uploaded with ImageShack.us
Old 18th April 2011, 12:23 PM   #10
Hello again
The kit arrived today (with €50 customs )
As I told before, I am not able to find appropriate transformer from Hammonds offering (due to lack of knowledge). Somehow I don't understand the specs provided by S5.
Can anyone help with this and my previous questions?
I will have a read thru the upgrade threads for the K-16LS and K-8LS and see what I can implement to mine.
Danny
need help with adding headphone output to S5 Electronics kit / K501 kit Neville Headphone Systems 0 29th January 2007 09:23 PM
How to convert S5 K-12g kit to dual mono? downward_dog Tubes / Valves 4 11th January 2007 12:57 PM
LM 4780 Mono Bassterror Chip Amps 5 11th June 2006 05:04 AM
LM 4780 Mono Amp NEWBIE Dominick22 Chip Amps 1 25th November 2005 05:20 AM
Page generated in 0.11222 seconds (81.03% PHP - 18.97% MySQL) with 10 queries
