Looking for goodme proven 2A3 SE project - Page 3 - diyAudio
Old 10th April 2011, 07:42 PM   #21
Bigun is offline Bigun  Canada
Bigun's Avatar
I believe both technologies can be used to make a very good power supply.
For my SS amps I use SS power supply - no choice really because SS is low voltage high current and high current tube rectifiers are rare beasts. It's also hard to make chokes for very high current so my SS supplies are all currently CRC.
For my tube amp I use a tube rectifier, choke loaded with NO capacitors between the rectifier and the choke, good quality caps after the choke, i.e. LC. This is a very different animal to the type of SS power supply I used for my SS amplifiers. I really like this approach very much. A choke loaded supply has drastically reduced charging spikes through the rectifier for much less 'hash/noise'. I also like the built-in slow turn on and turn off that is achieved with tube rectifiers and believe they produce less noise compared with SS diodes. And if you are building a tube amp, just one more tube seems to be within the spirit of things !
Others with more experience that I who may have had the chance to compare the different types should be able to offer better advice.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 13th April 2011, 05:21 PM   #22
Default SE Transformers?
What transformers are the best for SE 300B ?
Anyone knows approx. prices of Tribute transformers and how they sound in comparison to Lundahl?
Old 19th April 2011, 04:58 PM   #23
Does it take long to get any reply from Tribute , I wrote to them almost 2 weeks ago and still no answer?
Anyone knows they prices ?
Best Regards
Old 19th April 2011, 05:04 PM   #24
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
for transformers try
Electra-Print.com High-Fidelity Audio Tranformers and Tube Amplifiers
great guy, product and price....
Old 19th April 2011, 05:13 PM   #25
I might give them a try , trouble is I am located in Europe , and buying from US = high delivery cost + duty charge.
That's the reason I wrote to Tribute , also I am considering Lundahl , what else?
Old 19th April 2011, 05:20 PM   #26
Did you compare those transformers with other "well known" trafos?
In what application have you used Electra-Print , SE or PP?
Old 19th April 2011, 05:22 PM   #27
Just so busy Slav,
Answer is coming your way this evening.
Pieter
Old 19th April 2011, 05:35 PM   #28
Thanks Pieter
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Looking for a good proven project for P17WJ / MDT33 b jmillerdoc Multi-Way 0 1st March 2009 04:07 PM
2A3 SE Amp widowmaker Tubes / Valves 16 7th November 2008 04:53 AM
parallel SE 2A3 sunrise Tubes / Valves 20 29th August 2008 07:41 PM
WTB: OPTs for 2A3 or 45 SE; 240 v power tranny for 2A3 or 45 rick57 Swap Meet 0 8th November 2006 01:07 AM
Copyright 1999-2017 diyAudio
