diyAudio Sponsor
Old 8th April 2011, 05:12 PM   #1
Default Plate Characteristics for 6158 dual triode
I've been search without success for plate characteristics plots for the 6158 aka 13D3.
TDSL doesn't have a link and my RCA and Sylvania manuals have nothing. All I've really learned is that there is 6158 miles of coastline in Scotland.
Does anyone have one?
Old 8th April 2011, 05:14 PM   #2
rsumperl's Avatar
Hope this helps: http://tubedata.milbert.com/sheets/019/6/6158.pdf
Ray
Old 8th April 2011, 05:17 PM   #3
Yes it does, thank you Ray.
A guy gave me a sleeve of them but they don't look very linear, judging by that curve.
CD
Old 8th April 2011, 06:45 PM   #4
rsumperl's Avatar
I find it amusing that the datasheet says: "Trustworthy Double Triode"
Old 8th April 2011, 07:56 PM   #5
316a is offline 316a  England
316a's Avatar
It really is a lovely valve , I use this type in my 'beercan' amp driving A2293 I rate these along with E80CC and 12AY7 as the nicest sounding 9 pinners that fit the 12A*7 pinout . If the valve has the 'T' for Trustworthy logo it's probably going to be the CV4068 special quality version , early types had the double getter support in keeping with the Mullard/Brimar/GEC tradition with ruggedised valves . As far as I can tell , like the 6BR7 , Brimar was the only manufacturer of these
316A
Old 9th April 2011, 07:02 PM   #6
I like the beer can amp! How many watts liter?
Calculate triode strapped characteristics from pentode data? mnturner Tubes / Valves 6 21st November 2010 02:53 AM
Will differential share the same THD characteristics as SE, if same triode is used? Kenneth Zhu Tubes / Valves 38 26th December 2007 01:17 AM
Plate characteristics rossdt Tubes / Valves 8 7th August 2006 06:03 PM
GM70 **COPPER PLATE** triode redwine1118 Swap Meet 1 5th May 2004 03:36 AM
More 6158/13D3 7N7 Tubes / Valves 68 2nd February 2003 12:37 AM
Page generated in 0.07558 seconds (72.47% PHP - 27.53% MySQL) with 11 queries
