Old 8th April 2011, 04:09 PM   #1
ixe13 is offline ixe13  Canada
Default Center tap or not...
I need extra filaments 10 volts AC taps for 2 310A tubes, I suppose I can use a totally independant small transformer (1 Amp) from the main tranformer, and connect the 2 301A filaments in parallel?
But, does it need to be center tap? cause without the center tap it's much smaller. Not much room in the chassis
Would save me from having to buy a new power transformer.
Old 8th April 2011, 04:34 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
You can balance filament by a pair of 100 Ohm resistors. They are small. So center tap is not necessary.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 8th April 2011, 04:41 PM   #3
Hi Wavebourn,
Please forgive my ignorance, how can I do that?
Thanks,
Old 8th April 2011, 04:45 PM   #4
kevinkr's Avatar
Originally Posted by ixe13 View Post
Hi Wavebourn,
Thanks,
Wire the two resistors in series across the filament lines, ground the center between them. Use a pair of 100 ohm 5% 1W metal oxide or similar.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 8th April 2011, 05:23 PM   #5
kevinkr, cool, thanks
like this:
Old 8th April 2011, 06:31 PM   #6
like this:
Actually it was meant as a question : Like this?
to all...
Old 8th April 2011, 10:45 PM   #7
Send a message via AIM to DigitalJunkie
Yep,like that.
Old 8th April 2011, 11:14 PM   #8
Awwwright,
Thanks guys,
Center-tap Choke SonnyOneness Power Supplies 21 2nd December 2010 05:51 PM
No center tap Help FastEddy Power Supplies 57 19th April 2010 07:01 PM
Center-tap to ground? cbutterworth Tubes / Valves 3 17th January 2007 09:18 PM
Center-tap to ground? cbutterworth Power Supplies 0 17th January 2007 03:41 PM
Transformer Center Tap dswiston Parts 2 4th February 2004 03:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
