Philips Hi Z radio amp
Old 8th April 2011, 09:23 AM   #1
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
Default Philips Hi Z radio amp
schematics anyone? Around 1959 model number is B5Z92A. its an AM / SW radio with input for tape and a turntable (probably ceramic cart). Definitely stereo, seems to be EL84 outputs.
Any help from our Euro members appreciated!
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 8th April 2011, 09:54 AM   #2
DF96 is offline DF96  England
Try UK Vintage Radio forum. Click the panel at the top right, and search for your radio. You will have to pay for a download, but it funds the forum so going to a good cause!
Old 8th April 2011, 03:28 PM   #3
mastodon is offline mastodon  Netherlands
mastodon's Avatar
It seems akin to this one: http://www.datastress.com/~mario/rad...&brand=Philips
At least, judging by type number and specifications. I wouldn't be surprised if the electronics are in fact identical.
Old 8th April 2011, 09:43 PM   #4
zero from 2, but thanks for the advice guys.
THe search goes on....
Old 9th April 2011, 10:40 AM   #5
analogadikt is offline analogadikt  India
Hi a10,
That radio was the top of the Philips radio line up here. It was branded Philips Maestro in this market and was usually installed in stereo consoles, but the net throws up only some R2Rs with that model name. Apart from vintage -radio, you can also try mfbfreaks .nl. That site is full of Philips gear nuts and somebody may have the information.
analogadikt
Old 9th April 2011, 01:30 PM   #6
Jaap is offline Jaap  Netherlands
Jaap's Avatar
looks like this one: http://www.philipsradios.nl/Schemas/B5X94A.pdf
Old 10th April 2011, 02:10 AM   #7
thanks guys, but still not there...
Philips Hi Z radio ampHide this!Advertise here!
Help Old Radio Philips ervinl Tubes / Valves 6 16th December 2010 09:30 PM
Radio output before transistor amp Calamaro Analogue Source 0 10th October 2008 01:00 PM
Wanted: Vintage radio schematic - Philips B5CA66U (India) Dr. Ram Everything Else 3 23rd June 2008 03:24 AM
Philips Tube radio Grifon Tubes / Valves 5 20th September 2007 03:40 AM
Simple amp is a radio , what to do ? fortuosity Solid State 3 6th May 2006 11:30 AM
