Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
I need help modifying the bias reference point in my Beard P100 tube power amp. The amplifier uses a LED biasing scheme where you turn the pot until the bias led turns off. Currently the circuit is calibrated for ~40ma bias current. I want to raise this to 55mA bias and make it adjustable so that I can calibrate and change the reference point for all power tubes with one adjustment. In the attached schematic how is this best achieved? I assume I need to change the reference voltage to something other than the set 0.5v but I am not sure how to do this. Any help will be greatly appreciated. Thanks ronenash
ronenash |
#2 |
My suggestion would be to add a 100 ohm pot in series with the 560 ohm resistor. This would allow a small adjustment to the bias reference voltage e.g. 0.5v to 0.6v.
You could, alternatively, reduce the value of the 4k7 with a parallel high value resistor. Start with 100k and work down the values till you get the bias you're looking for. |
#3 |
Thanks, but these two suggestions seem to conflict as adding the 100 ohm resistor in series will raise the overall resistance and adding a 100K resistor in parallel with the 4K7 resistor will lower the overall resistance.
Am I making sense?
ronenash |
Thread | Thread Starter | Forum | Replies | Last Post |
Modifying 100 watt LXI amplifier circuit | CrazzyAbtTubes | Solid State | 19 | 30th November 2009 01:17 AM |
Help modifying circuit | Rob11966 | Tubes / Valves | 14 | 3rd November 2008 05:14 AM |
modifying MIDI circuit boards/patching into consumer keyboards? | VvvvvV | Instruments and Amps | 17 | 21st June 2007 11:31 PM |
Modifying 200W gainclone circuit | soundNERD | Chip Amps | 3 | 6th July 2006 01:58 AM |
New To Site? | Need Help? |
