diyAudio Sponsor
Old 6th August 2003, 03:14 AM   #1
Default 5687 line amp with 0D3 regulator
Well, its up and running. The first tube sounded like crap and was microphonic. I can only assume that it was bad to the bone. I replaced it with another Tung Sol and its sounding and running mighty fine. I will have to admit that it is the best sounding line amp I have heard yet. I settled for a plate voltage of 135volts and cathode voltage of 5.0 volts. With the 470 ohm cathode resistors I make this out to be about 10.6 mA per section. I assume it is within safe operation for the tube.
Frank
I haven't been able to download a grid sheet on the tube so maybe someone could send me one thru email. Frank I think regulation helps with the sound. It sounds better with the 0D3 than it does unregulated.
I didn't think the chokes made it sound unnatural either.
Joe
Old 6th August 2003, 04:00 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
So you got a schematic for it yet?
BTW a good rule of thumb is to have maybe half the supply voltage across the plate resistor, and the other half across the tube (Vp=75V in your case). If it's heavily loaded (Rl = 1 or 2 * plate load R), as low as Vp = 1/3 B+ may be necessary for low distortion. But it all depends on your requirements.
Glad you like it.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 6th August 2003, 09:00 AM   #3
diyAudio Senior Member
fdegrove's Avatar
It's on its way already.
No surprise to me but you can only be sure if you compare the two under the same working conditions...
Was that the case?
By the way, are you using one OD3 per channel or is it common to both?
Frank
Old 6th August 2003, 11:09 AM   #4
I'll try to send a schematic
Old 6th August 2003, 11:25 AM   #5
I'm using a 2K grid resistor and ending up with 135v on the plate.
The 0D3 is providing the regulation to both channels. I am considering using a 0D3 per channel. I tried using a voltage dropping resistor before the 0D3 but that wouldn't let the 0D3 fire up. The power supply consists of a Hammond 272BX transformer, a 6X4 rectifier tube, a 30H choke followed by a 50mfd cap to ground followed by another 30H choke and another cap to ground. The 0D3 goes from B+ to ground and the grid resistors attach to pin 5 of the 0D3.
Now, if someone can tell me what I am doing wrong here it would be appreciated. The problem seems to be that I cannot get the 0D3 to stay lit with the correct load dropping resistor. I can get it to work by using the load provided by the plate resistors and the tube draw.
Old 6th August 2003, 11:37 AM   #6
Frank
Thanks for the info.
I listened to the line amp with the 0D3 out of circuit and the appropriate plate resistor to achieve the same plate voltage as with the 0D3. It sounds more dynamic with the 0D3.
Joe
Old 6th August 2003, 08:56 PM   #7
Sch3mat1c's Avatar
Yikes!! For one thing the most capacitance across a reg tube should be .1uF -- you have 50! I guess the only thing keeping it from oscillating is the extreme current going through it, which should roast the 6X4 pretty quickly too.
Tim
Old 6th August 2003, 09:06 PM   #8
fdegrove's Avatar
Where? I don't see any cap across it.
What extreme current? The 6X4 is good for 70 mA with an LCL filter, so ?
If you want something to chew on, this could make you happy.
Frank
Old 6th August 2003, 09:08 PM   #9
Sch3mat1c's Avatar
I didn't see any resistors on the bitmap he attached.
Here's a circuit. HTH.
Tim
Old 6th August 2003, 09:21 PM   #10
Brett's Avatar
Joe,
Replace the 3k with a CCS set for 28mA. A DN2540 or an IRF820 would do.
5687 fully balanced line stage cedus Tubes / Valves 14 24th July 2009 01:28 PM
5687 line stage costa23 Tubes / Valves 35 10th August 2008 09:53 AM
Regulator for RIAA Preamp and Line Amp wrenchone Solid State 13 3rd February 2008 09:15 AM
5687 dc 5687 tube amp need help vangogh-hk Tubes / Valves 8 4th January 2006 12:09 AM
5687 Line Stage karma Tubes / Valves 16 3rd June 2003 09:44 PM
Page generated in 0.11910 seconds (79.47% PHP - 20.53% MySQL) with 12 queries
