Would it be possible to drive a 300b with new power jfets? - diyAudio
Old 4th April 2011, 02:18 AM   #1
JZatopa is offline JZatopa  United States
Default Would it be possible to drive a 300b with new power jfets?
If I understand this right these new Semisouth Jfets can handle some pretty high voltage. What do you guys think about driving a 300B, 2a3 or possible a 847 tube with one? Is there something I am missing with this idea?
Old 4th April 2011, 03:27 AM   #2
TheGimp is online now TheGimp  United States
TheGimp's Avatar
Tubelab Power Drive:
PowerDrive
Old 4th April 2011, 06:28 AM   #3
Interesting read, something I may try at a later date but not quite what I am talking about. What I am talking about would be an amp with a jfet directly driving a tube.
Old 4th April 2011, 07:42 AM   #4
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Im not knocking your idea, but isn't the virtue of tubes the linear voltage amplification and that of solid state devices the ability to deliver current? What is your motivation for doing it the other way round, apart from "because you can"
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 4th April 2011, 08:58 AM   #5
mastodon's Avatar
Correct me if I'm wrong, but I thought that both valves and FETs are essentially voltage controlled current sources.
Old 4th April 2011, 10:19 AM   #6
yes thats my understanding too, but fets are capable of delivering more current.
Old 4th April 2011, 03:53 PM   #7
Sheldon is offline Sheldon  United States
They don't look very linear to me, although it's hard to tell, because the curves on their spec sheets are for much higher currents that you'd ever use in a driver for an output tube. Also, the input capacitance is about 10 times or more than would be typical for a driver tube, so your source would have to be capable of driving it.
Of course, you can get around those issues, with cascoding, feedback (degeneration), etc., but I'm not sure what the benefit would be.
Sheldon
Old 4th April 2011, 04:22 PM   #8
This was more of a "could it be done" question. I have not seen an amp that uses only a single high power output tube and no other tubes. I wonder if it would be one of those things where the amp sounds better then what it's measurements would show.
A tube driving a power jfet would seem more obvious but similar hybrid amps already exist.
Old 4th April 2011, 04:50 PM   #9
Sure, it can be done. But as mentioned previously in the thread, the high voltage FET's that are available are pretty high current devices. And in a tube amp, it doesn't make much sense to have your driver stage eating up much current, certainly not more that the output tube. That doesn't mean that you can't use these devices at lower current, but I think they will be much less linear than available tube choices for the same application. And, they have much higher input capacitances. You can deal with those issues, but what have you gained, as a practical matter?
I'm by no means an expert on any of this, take the following with that in mind. The FET's designed for audio are more linear, but also for the lower voltages typical of SS amps. And there seem to be small signal devices (linear, low voltage) and output devices (high current), with little in between. I would guess that audio FET's could be designed to substitute pretty well for a driver tube but there's no commercial reason to do so. So unless it accidentally fits well with some other application, it won't happen.
Sheldon
Old 4th April 2011, 05:14 PM   #10
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
In one of my designs 6P15P drive Semisouth JFETs. Incredible sound.
The Devil is not so terrible as his math model is!
300B - Push Pull or PSE to drive a commercial speaker arnoldc Tubes / Valves 74 28th June 2013 10:12 AM
SemiSouth SiC Power JFETs RocketScientist Solid State 105 19th February 2012 08:02 PM
Amazing Circlotron with Power JFets Ejam Pass Labs 22 21st September 2009 01:51 AM
Best way to use a PAIR of 6SL7ís to drive a 300B? sgerus Tubes / Valves 5 11th December 2007 12:41 AM
Copyright ©1999-2017 diyAudio
