Hi all,
I have a whole bunch of NOS Octal tubes just sitting around. I also have some free time on my hands. I want to combine these to create the Ultimate Octal Amp. The tubes I have include 6SF5GT 6SJ7GT 6SL7GT 6SN7GT. I'd like to combine these with a flexible power stage which can use EL84, KT88 or 6L6GT depending on my mood. I like tube power supplies, but I'm not obsessive, what ever is best will do. Any ideas ? I'm looking to build something interesting to look at and great to listen to. I certainly could not do this without your input, hence this post. Here goes.... Klaatu
Resistance is futile ! |
#2 |
You should be able to build a decent Mullard style circuit with a 6SJ7 voltage amplifier, a 6SN7 LTP, and either KT88 or 6L6 "finals". Forget about different O/P types, as the O/P trafo that's optimal for 1 type will be anything but with another.
Don't forget to CCS load the LTP's tail. Should that require a negative rail, so be it.
Eli D. |
#3 |
Have a look at this very long thread. I have used a 6SL7 or a 6SN7 in the first stage and a 6SN7 for the second stage, depending on how much gain you need and how much feedback you use.
6L6GC AB2 Amp
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| all-octal schaded pp | aardvarkash10 | Tubes / Valves | 9 | 2nd July 2010 11:43 PM |
| Octal Aikido? What tubes? | jayme | Tubes / Valves | 8 | 31st December 2006 03:03 AM |
| Octal pentode sub for ef86? | 2004ex | Tubes / Valves | 5 | 14th November 2006 05:37 AM |
| Octal - Tubepreamp For Sale | WALTER BURKHARD | Swap Meet | 0 | 8th September 2005 11:30 AM |
| Octal Cornet | RogueAngel | Tubes / Valves | 2 | 19th September 2003 01:23 AM |
